بعض الاسئلة التى وردت فى مقابلات شخصية لمهندسين كهرباء
#1
ماهى أهم البيانات على لوحة بيانات الموتور ؟
Rated voltage or voltages
Rated full-load amps for each voltage level
Frequency
Phase
Rated full-load speed
Insulation class and rated ambient temperature
Rated horsepower
Time rating
Locked-rotor code letter
Manufacturer’s name and address
Frame size
Full-load efficiency
Power factor
THE RUNNING SPEED OF 3 PHASE ‎INDUCTION MOTOR IS
‎1.SYNCHRONOUS SPEED‎
‎2.LESS THAN SYNCHRONOUS SPEED
‎3.MORE THAN SYNCHRONOUS SPEED
IF THE ACTUAL SPEED OF INDUCTION ‎MOTOR IS EQUAL TO SYNCHRONOUS SPEED
‎1.DEVALOPE TORQUE‎
‎2.NOT DEVELOP TORQUE.‎
NOT DEVELOP TORQUE
COMMONLY USED A.C. MOTOR FOR ‎INDUSTRIAL DEVICES IS
‎1.SYNCHRONOUS MOTOR‎
‎2.COMMUTATOR MOTOR‎
‎3.3 PHASE INDUCTION MOTOR
‎3 PHASE INDUCTION MOTOR
A 3 PHASE INDUCTION MOTOR IS ‎
‎1.SELF STARTING‎
‎2.NOT SELF STARTING‎
SELF STARTING
THE NUMBER OF POLES OF A 3 PHASE ‎INDUCTION MOTOR AT60 CYCLES RUNNING ‎BELOW 1500 RPM WILL BE
‎1.4 POLE‎
‎2.6 POLE‎
‎3.2 POLE‎
‎6 POLES
THE DIRECTION OF ROTATION OF 3 PHASE ‎INDUCTION MOTOR IS
‎1.SAME AS THAT OF ROTATING MAGNETIC ‎FIELD
‎2.OPPOSITE TO THE DIRECTION OF ‎ROTATING MAGNETIC FIELD
…THE TORQUE IN A 3 PHASE INDUCTION ‎MOTOR IS PROPORTIONAL TO
‎1.APPLIED VOLTAGE‎
‎2.SQUARE OF THE APPLIED VOLTAGE .V2‎
‎3.SQUARE ROOT OF APPLIED VOLTAGE
WHAT IS THE DIFFERENCE BETWEEN ‎STARTING OF 3PHASE AND SINGLE PHASE ‎INDUCTION MOTORS?‎
‎3 PHASE MOTOR IS SELF STARTING ‎WHEREAS 1 PHASE MOTOR IS NOT.
WHAT ARE THE DIFFERENT METHODS OF ‎STARTING OF 3PHASE INDUCTION MOTORS?‎ ‎
1) DIRECT ON LINE‎
‎2) STAR /DELTA ‎
‎3) REACTOR STARTING‎
‎4) AUTO TRANSFORMER
WHAT IS THE EFFECT OF UNDER VOLTAGE ‎ON 3PHASE INDUCTION MOTOR ?‎
THE MOTOR TAKES MORE CURRENT FOR ‎THE SAME LOAD.
IF YOU HAVE A MOTOR OF MORE THAN 100 ‎KW CAPACITY AND YOU ARE ASKED TO COMMISSION IT, WHAT SUGGESTIONS YOU WILL GIVE FOR SELECTING THE SWITCHGEAR AND PROTECTION ?‎
IT IS NORMAL PRACTICE THAT WHENEVER THE MOTOR CAPACITY INCREASES
BEYOND ‎‎90 KW THE USE OF CIRCUIT BREAKER IS MADE INSTEAD OF POWER CONTACTOR DUE ‎THE LIMITATION OF ITS DESIGN. AS ‎REGARDS THE PROTECTION THE USE OF ‎THERMAL BI -****LLIC RELAY IS AVOIDED ‎AND USE OF MOTOR PROTECTION RELAY IS ‎MADE WHICH SHOULD HAVE THE ‎FOLLOWING FEATURES:‎
A) SHORT CIRCUIT PROTECTION ‎‎(INSTANTANEOUS) TO BE SET TO 6 TO 8 ‎‎* IN (IN=RATED CURRENT OF MOTOR).
B) BLOCKED ROTOR PROTECTION (AGAINST ‎STALLING OF MOTOR TO BE SET 2 *IN‎AND DELAYED BY THE STARTING TIME ‎OF MOTOR).‎
C) NEGATIVE PHASE SEQUENCE ‎PROTECTION.‎
D) EARTH FAULT PROTECTION.‎
E) THERMAL REPLICA
what are the conventional ways by which the speed of a polyphase induction motor can be changed ?
answer :
1- For squirrel cage motor
- by using a stator winding which can be connected for a different no of poles .
by varying the frequency
2- For wound rotor:
- by cascade connection of two or more motors.
- by inserting voltage in the rotor circuit.
- by inserting resistance in the rotor circuit
ما هى علاقه التردد بالعزم ؟
العلاقه عكسيه حيث انه كلما زاد التردد (زادت السرعه)يقل العزم حسب العلاقه:
P=T*W
P=TKF
اذن الTتتناسبعكسيا مع الF
Pقدرة
Tعزم
Fالتردد
kثابت التناسب
ماذا يعنى أن درجة عزل المحرك من النوعF وما الفرق بينه وبين آخر درجة عزله من النوع B ؟
الإجابة
يوجد أربعة أنواع من درجات عزل ملفات المحرك التى تصنف تبعاًلأقصى درجة حرارة للتشغيل المتواصل:
1- درجة العزل E وتكون حرارة العزل لهذة الدرجة 75
2- درجة العزل B وتكون حرارة العزل لهذة الدرجة 80
3- درجة العزل F وتكون حرارة العزل لهذة الدرجة 100
4- درجة العزل H وتكون حرارة العزل لهذة الدرجة 125
أى أن المحرك الذى يكون درجة عزل ملفاته من النوعFيتحمل العمل عند درجات حرارة أعلى من نظيره الذى يكون درجة عزل ملفاته من النوعB ولكن ذلك على حساب التكلفة حيث أنه تزيد التكلفة فى درجة العزل F عنها فى درجة العزل B.
ما المقصود بالرقم 100 الذي بجوار PT في أسم حساس درجة الحرارة PT100?
هي قيمة المقاومة عند الصفر المئوي ويقصد بها أن قيمة المقاةومة التي يقرأها يحولها الحساس عند درجة الصفر المئوي هي100 أوم
هل هناك أنوع لمحركات التيار المستمر ؟
تصنف المحركات علي حسب التوصيل لملفات التوالي والتوازي مع العضو الدوار
إلي محركات التوالي – محركات التوازي –محركات مركبة
ماذا عن الترياك؟
هو العنصر الذي يمكن التعبير عنه 2ثايرستور عكس بعض
ماذا عن الدياك ؟
هو العنصر الذي يمكن التعبير عنه 2دايود موصلين عكس بعض
what are disadvantages of low power factor?
1. large KVA rating of equipment
2. Greater conductor size
3. large copper losses
4. poor voltage regulation
5. Reduced handling capacity of system
كيف يمكن تحويل المحرك ثلاثي الاطوار الي احادي
1- اثناء اعادة لف الموتور او التصنيع حيث يتم دمج 2 فاز ( طورين ) معا بواسطة مكثف ويكةن هو الطرف الموجب والطرف الاخير هو المتعادل لخطي الكهرباء
2 - يمك من خلال روزتة الموتور الثلاثي دمج 2 فاز معا خرجيا بمكثف والطرف الغير مستخدم هو المتعادل
Classify the power converters
Power converters can be classified into many types according to their type of electrical conversion.
Inverter is one of these families which converts the power from DC power with DC voltage to AC power with V (Voltage) and f (frequency).
Rectifiers convert the AC power V (Voltage) and f (frequency) to DC power level VDC.
Choppers are dc-dc converters, converts directly dc to dc.
AC/AC Converter (Matrix Converter) converts the AC power from a voltage or a frequency level into another level
ما هى انواع rectifier؟
half wave controlled rectifier-1
full wave controlled rectifier-2
half wave uncontrolled rectifier-3
full wave uncontrolled rectifier-4
