[CENTER][B]Oxy-Hydrogen Generator (HO3000)
Product Description
Technology Theory
Oxy-hydrogen machine is a high-tech product in the world. It adopts water electrolysis technology to decompose hydrogen and oxygen from water under electricity, this machine uses hydrogen as the fuel and oxygen as the combustion-supporting gas in polishing, brazing, cutting, welding, furnaces; Oxy-hydrogen machine is a very promising and practical equipment, friendly to environment in the meantime.
Multi-purposes
This machine might turn water into flame which is like that produced by oxy-acetylene, oxy-propane and oxy-LPG and can do same work like cutting carbon iron, metal welding, processing headgears, jewelries, gold, platinum, silver, glassware.
Safe energy
Oxy-hydrogen is a very safe fuel, no poison, no harming smell to human body. Hydrogen has the smallest density among all gases, once leaking it will escape to the air quickly and not as dangerous as LPG, acetylene etc.
Easily procured energy sources
Oxy-hydrogen fuel is easily procured as we can find water and electricity easily. It can save much energy other than using acetylene, propane, LPG, etc., for example, each cubic oxy-hydrogen gas consumes 0.5 liter water and 3.5 KW electricity which is cheaper cost than using acetylene.
Working features compared with tradtional oxy-fuels
As oxy-hydrogen flame body is slimmer than other flame bodies, it has advantages like narrower slit, focused firepower, little heat affection area, high heat value, faster preheating, better cutting quality. The following is the workpiece cut by it:
When welding, the welding surface is glossy, if filling a little gasoline or alcohol, the welding piece will be oxidation resistant.Model: HO3000[/b][/center]
