Buckling Analysis of Thin Laminated Composite Plates using Finite Element Method
First order shear deformable plate theory (FSDT) is used to study buckling of thin laminated composite plates. Finite element method (FEM) is utilized to obtain numerical solution of the governing differential equations. Buckling analysis of laminated plates with rectangular cross – section for various combinations of end conditions and aspect ratios is studied. To verify the accuracy of the present technique, buckling loads are evaluated and validated with other work available in the literature. The good agreement with other available data demonstrates the reliability of finite element method used. New numerical results are generated for uniaxial and biaxial compression loading of symmetrically laminated composite plates. It was found that the effect of boundary conditions on buckling load increases as the aspect ratio increases for both uniaxial and biaxial compression loading. It was also found that, the variation of buckling load with aspect ratio becomes almost constant for higher values of elastic modulus ratio.
Keywords: Finite element method, first order shear deformation theory, buckling, thin plates, laminated composites.Buckling Analysis of Thin Laminated Composite Plates using Finite Element Method.pdf (685.4% u)
(عمارة إسلامية) #2
السّلام عليكُم ورحمة الله وبركاته
ما شاء الله!
جزاكُم الله تعالى خيرًا أخي د. أسامة.
وعودة ميمونة بين إخوتكم في مُنتدى المُهندس.
جعل الله تعالى ما أودعتُم في ميزان حسناتكُم ووفقكم.
(osama mohammed elmardi suleiman khayal) #3
thank you
