Mechanical Properties of Composite Laminated Plates
Impact Factor (JIF): 2.712 Downloaded @
Osama Mohammed Elmardi Suleiman
Department of Mechanical Engineering
Faculty of Engineering and Technology
Nile Valley University,
Atbara – Sudan
A composite material can be defined as a combination of two or more materials that
gives better properties than those of the individual components used alone. In contrast to
metallic alloys, each material retains its separate chemical, physical, and mechanical
properties. The two constituents are reinforcement and a matrix. The main advantages of
composite materials are their high strength and stiffness combined with low density when
compared to classical materials. Micromechanical approach is found to be more suitable for
the analysis of composite materials because it studies the volume proportions of the
constituents for the desired lamina stiffness and strength.
published-pdf-21015035-6-2105035.pdf (119.2% u)
(عمارة إسلامية) #2
ما شاء اللهُ!
جزاكم الله تعالى خيرًا أخي د. أسامة.
يبدو كتابًا قيّمًا جدًّا لأهل التخصّص!
فجعله الله تعالى لكم شاهدًا،
وزادكم سُبحانه من واسع علمه وفضله.
(osama mohammed elmardi suleiman khayal) #3
thanks for your appreciation
