Plate'n'Sheet Professional Version 4
(Ahmed) #1
Plate ‘n’ Sheet Professional Version 4
برنامج جميل جد متخصص في عمل أفرادات و حسابات الصاج مع عمل الرسومات - CAD - لها وأمكانية تصدير الرسمة الي برنامج AutoCAD
وكذلك حفظها بصيغة DXF
والشرح التالي من الموقع الرسمي للبرنامج وفي أخر الموضوع توجد روابط البرنامج مباشرة
Plate’n’Sheet Professional Version 4 Feature List.
Overview.
Drawing from feedback received from our clients over the duration of Version 3, we have made major changes to Version 4 to provide more shapes and more options within the shapes and more additional features to make your job easily.
‘Ease of use’ is our guiding principle. In Version 4 we believe we have been able to provide many additional features while maintaining the program’s original simplicity for the basic user.
More shapes
In addition to Pipe to Pipe and Pipe to Cone, branches now include Cone to Cone, Cone to Oblique Cone, Cone to Pipe, Pipe to Oblique Cone, Rectangle to Cone, and many more.
Multiple branches, with up to four pipes converging on a common intersection point.
HVAC Rectangular Ducting (reducers, branches, Y’s, T’s). More Transitions.
More Segmented bend options.
Vessel End Caps (hemispherical, torispherical, semi elliptical).
New Category Menu
Shapes are easier to find.
Provides a better foundation for continuing expansion of the system.
Material Thickness.
Thickness setting is now more conveniently located.
Improved Manual Dimensioning
New horizontal, vertical and offset dimensions.
Improved Automatic Dimensioning.
True lengths with separate Step-off dimensions around the top and base.
Individual Auto Dimensions may now be deleted or modified for a more readable drawing.
Now includes Bend Angles.
New option now prints the angle between two faces along the press line.
Router depth for the plastics industry.
Improved Printing
A Print Preview window now shows you exactly what you will get on the paper.
Improved Viewing
Dynamic Pan and Zoom.
Dynamically rotate the 3D model in real time.
Improved Lap Join Settings
Easier to use.
More accurate.
Move and Rotate
Move individual patterns in compound shapes for more efficient use of material.
Pattern Identification
Patterns may now be automatically stamped with the date, time, item number and project number if required.
Area and Mass Calculation
Automatically calculate the rectangular area and mass.
Automatically calculate the true area and mass of the cut shape.
Material Cost
Speed up quoting by automatically calculating the cost of material.
Includes a database that you can easily maintain with current material prices.
Improved communication with AutoCAD
Dimensions and text now transfer as native AutoCAD objects.
The 3D wire-frame model may be transferred to AutoCAD.
The views of the model may now be transferred as 2D views.
The above features also apply to AutoCAD LT via the Export DXF process.
Send to AutoCAD now supports AutoCAD 2000 to 2011 (not AutoCAD LT).
The Export DXF method may be used with AutoCAD LT (all versions) AutoCAD 12 to AutoCAD 2011, IntelliCAD and many other CAD programs.
رابط التنزيل
http://plate-n-sheet-professional.software.informer.com/download/
او من خلال سيرفر المنتدى
pns_ev4_10_02.zip (19.8% u)
أتمنى أن يفيدكم وشكرا
#2
جزاك الله خيرا مهندس أحمد على مشاركتك القيمة معنا فى المنتدى ولكن للاسف لم اتمكن من تحميل البرنامج تظهر لى هذه الرسالة
Sorry, the page you’re looking for isn’t here
#3
جزاك الله خيرا مهندس احمد مرة اخرى وللعلم فقد تم تعديل رابط التحميل واعادة الرفع على سيرفر المنتدى
(Ahmed) #4
الرابط التالي - أن شاء الله - شغال
