: اكاديمية المستقبل للتدريب
[RIGHT]اليوم الاول
o Basic Concepts, Properties of Fluids .and Classification of Flows.
o Pressure, Fluid Statics, Buoyancy and Archimedes Principle.
o Fluid Kinematics; Acceleration Field, Streamlines, Pathlines, Streaklines, Translation and Rotation, Vorticity and Rotationality.
[RIGHT]اليوم الثاني
o Conservation of Mass, General Energy Equation, Energy Analysis of Steady Flow, Bernoulli Equation, HGL and EGL, Applications.
o Momentum Analysis of Flow Systems, Linear and Angular Momentum Equations, Applications.
[RIGHT]اليوم الثالث
o Flow through Pipes, Laminar and Turbulent Flows, The Entrance Region, Fully Developed Pipe Flow, Wall-shear stress, Pressure drop and Friction Factor, Minor Losses.
o Differential Analysis of Fluid Flow, Conservation of Mass, The Stream Function, Conservation of Linear Momentum, Navier-Stokes Equation, Applications, Approximate Solutions of the Navier-Stokes Equation.
[RIGHT]اليوم الرابع
o Flow over bodies; External Flow, Lift and Drag, CD of Common Geometries, Boundary Layer, Flat Plate Drag, Cylinder and Sphere Drag.
o Compressible Flow, One-Dimensional Isentropic Flow, Isentropic Flow Through Nozzles, Shock Waves and Expansion Waves, Duct Flow with Heat Transfer and Negligible Friction, Adiabatic Duct Flow with Friction.
[RIGHT]اليوم الخامس
[RIGHT]
o Open Channel Flow; Classification, Froude Number and Wave Speed, Continuity and Energy Equations, Best Hydraulic Cross Sections, Hydraulic Jump, Flow Control and Measurements.
o Turbomachinery; Categories, Pump, Turbine, Compressor, Dimensional Analysis and Affinity Laws.
o Computational Fluid Dynamics (CFD); Model Equations, Discretization, Grid Generation, Boundary Conditions, Solve, Post-Processing, Uncertainty Assessment, Examples.
مده البرنامج : 5 ايام
تاريخ البدء : 10/7/2012
للحجز الالكترونى : http://www.futuretc.com/new/program_register.php?id=13261
الشهادات
شهادة هارفارد الدولية ببريطانيا بمسمى دبلومة[B][FONT=&]
: [/font][/b]للحجز ولمزيد من المعلومات يرجى الاتصال بالعناوين التالية
القاهرة
المهندسين: 37 ش غزة – متفرع من ش الرياض – متفرع من ش السودان
ت 0020233035736
موبيل : 00201113015715
المنصورة
:فرع ( كلية التربية
شارع جيهان - أمام بوابة جامعة المنصورة ( الجلاء - تربية ), برج العشرى - الدور الاول علوى
ت/ 00201145178289
موبيل [B][FONT=&] 0020502264691
[/font][/b]الموقع الالكترونى : www.futuretc.com
أو على الفيس بوك على الرابط التالى
www.facebook.com/futuretc.academy[B][FONT=&]
[/font][/b]المراسله عبر الأيميل:
[B][FONT=&]futuretraining_mansura1@yahoo.com[/font][/b]
أكاديمية المستقبل للتدريب
