تعريف ال G-code
G-Code
Description
G00
Rapid Linear Interpolation
G01
G02
Clockwise Circular Interpolation
G03
Counter Clockwise Circular Interpolation
G04
Dwell
G05
High Speed Machining Mode
G10
Offset Input By Program
G12
Clockwise Circle With Entrance And Exit Arcs
G13
Counter Clockwise Circle With Entrance And Exit Arcs
G17
X-Y Plane Selection
G18
Z-X Plane Selection
G19
Y-Z Plane Selection
G28
Return To Reference Point
G34
Special Fixed Cycle (Bolt Hole Circle)
G35
Special Fixed Cycle (Line At Angle)
G36
Special Fixed Cycle (Arc)
G37
Special Fixed Cycle (Grid)
G40
Tool Radius Compensation Cancel
G41
Tool Radius Compensation Left
G42
Tool Radius Compensation Right
G43
Tool Length Compensation
G44
Tool Length Compensation Cancel
G45
Tool Offset Increase
G46
Tool Offset Decrease
G50.1
Programmed Mirror Image Cancel
G51.1
Programmed Mirror Image On
G52
Local Coordinate Setting
G54 - G59
Work Coordinate Registers 1 Thru 6
G60
Unidirectional Positioning
G61
Exact Stop Check Mode
G65
Macro Call (Non Modal)
G66
Macro Call (Modal)
G68
Programmed Coordinate Rotation
G69
Coordinate Rotation Cancel
G73
Fixed Cycle (Step)
G74
Fixed Cycle (Reverse Tapping)
G76
Fixed Cycle (Fine Boring)
G80
Fixed Cycle Cancel
G81
Fixed Cycle (Drilling / Spot Drilling)
G82
Fixed Cycle (Drilling / Counter Boring)
G83
Fixed Cycle (Deep Hole Drilling)
G84
Fixed Cycle (Tapping)
G85
Fixed Cycle (Boring)
G86
G87
Fixed Cycle (Back Boring)
G88
G89
G90
Absolute Value Command
G91
Incremental Value Command
G92
Work Offset Set
G101
User macro 1 (substitution) =
G102
User macro 1 (addition) +
G103
User macro 1 (subtraction) -
G104
User macro 1 (multiplication) *
G105
User macro 1 (division) /
G106
User macro 1 (square root)
G107
User macro 1 (sine) sin
G108
User macro 1 (cosine) cos
G109
User macro 1 (arc tangent) tan
G110
User macro (square root)
G200
User macro 1 (unconditional branch)
G201
User macro 1 (zero condition branch)
G202
User macro (negative condition branch)
انا فعلا عاجز عن الشكر جزالله خيراً
شكرا لك على المشاركة
الشكر الجزيل لك اخي عبد الظاهر
الشكر لك اخى على الاهتمام المستمر على مواضيعى المتواضعة
الشكر الجذيل لك ومذيد من التألق
بارك الله فيك اخى العزيز
ان لم تكن متاكد من مشروعك فلا تذهب بنا الى الهاويه وشكرا لك
جزاك الله خير اخى العزيز
شكرا يا مهندس عبدالظاهر
اذا ممكن كتاب تعليمي لبرنامج artcam
من عيونى يابشمهندس حاضر قريبا
شكرا
السلام عليكم اخي عبد الظاهر وبارك الله جهودك والله يزيدك علم
ممكن توضيح لأيعازات G45-59 واكون شاكر لك
