دروس في الهيدروليك Lessons In Hydraulic Systems
السلام عليكم ورحمة الله وبركاته.
اقدم لكم هدا الموضوع عن الهيدروليك .
الهيدروليك اساسي ومهم نجده في كل الالات الميكانيكية منها السيارات والشاحنات والجرفات والجرارات.
هدا الموضوع ساقدم مبادئء الهيدروليك حيث ستكون سلسلة اقدم فيها كدالك
الهيدروليك في الجرارات والات الحصاد.
Hydraulic machinery
Hydraulic machinery are machines and tools which use fluid power to do work. Heavy equipment is a common example.
In this type of machine, high pressure hydraulic fluid is transmitted throughout the machine to various hydraulic motors and hydraulic cylinders. The fluid is controlled directly or automatically by control valves and distributed through hoses and tubes.
The popularity of hydraulic machinery is due to the very large amount of power that can be transferred through small tubes and flexible hoses, and the high power density and wide array of actuators that can make use of this power.
1-Force multiplication
An interesting aspect of hydraulic systems is the ability to apply force multiplication. Imagine if cylinder one (C1) is one inch in diameter, and cylinder two (C2) is ten inches in diameter. If the force exerted on C1 is 10 lbf, the force exerted by C2 is 1000 lbf because C2 is a hundred times larger in area (S = πr²) as C1. The downside to this is that you have to move C1 a hundred inches to move C2 one inch.
2-Hydraulic circuits
PISTON
VALVES
For the hydraulic fluid to do work, it must flow to the actuator and or motors, then return to a reservoir. The fluid is then filtered and re-pumped. The path taken by hydraulic fluid is called a hydraulic circuit of which there are several types. Open center circuits use pumps which supply a continuous flow. The flow is returned to tank through the control valve’s open center; that is, when the control valve is centered, it provides an open return path to tank and the fluid is not pumped to a high pressure. Otherwise, if the control valve is actuated it routes fluid to and from an actuator and tank. The fluid’s pressure will rise to meet any resistance, since the pump has a constant output. If the pressure rises too high, fluid returns to tank through a pressure relief valve. Multiple control valves may be stacked in series[1]. This type of circuit can use inexpensive, constant displacement pumps.
Closed center circuits supply full pressure to the control valves, whether any valves are actuated or not. The pumps vary their flow rate, pumping very little hydraulic fluid until the operator actuates a valve. The valve’s spool therefore doesn’t need an open center return path to tank. Multiple valves can be connected in a parallel arrangement and system pressure is equal for all valves
3-Constant pressure & load-sensing systems
The closed center circuits exist in two basic configurations, normally related to the regulator for the variable pump that supplies the oil:
Constant pressure systems (CP-system), standard. Pump pressure always equals the pressure setting for the pumpregulator. This setting must cover the maximum required load pressure. Pump delivers flow according to required sum of flow to the consumers. The CP-system generates large power losses if the machine works with large variations in load pressure and the average system pressure is much lower than the pressure setting for the pump regulator. CP is simple in design. Works like a pneumatic system. New hydraulic functions can easily be added and the system is quick in response.
Constant pressure systems (CP-system), unloaded. Same basic configuration as ‘standard’ CP-system but the pump is unloaded to a low stand-by pressure when all valves are in neutral position. Not so fast response as standard CP but pump life time is prolonged.
Load-sensing systems (LS-system) generates less power losses as the pump can reduce both flow and pressure to match the load requirements, but requires more tuning than the CP-system with respect to system stability. The LS-system also requires additional logical valves and compensator valves in the directional valves, thus it is technically more complex and more expensive than the CP-system. The LS-system system generates a constant power loss related to the regulating pressure drop for the pump regulator:
Power loss = ΔpLS·Qtot; The average ΔpLS is around 2 MPa (290 psi). If the pump flow is high the extra loss can be considerable. The power loss also increase if the load pressures varies a lot. The cylinder areas, motor displacements and mechanical torque arms must be designed to match in load pressure in order to bring down the power losses. Pump pressure always equals the maximum load pressure when several functions are run simultaneously and the power input to the pump equals the (max. load pressure + ΔpLS) x sum of flow.
4-Four basic types of load-sensing systems
(1) Load sensing without compensators in the directional valves. Hydraulically controlled LS-pump.
والسلام عليكم
ستكون تتمة للموظوع.
ما فيش ردود
thaaaaaaaaaaaanks
يعني عملت شنو
مشكور يا ورد
thxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
جزاك الله خيرا
جزاكم الله الف خير على هذه الدروس
جزاكم الله الف خير
مشكور ررررررررررررررررررررررررررررررررررررررررر
معلش سامحني ممكن توضحلي اكتر
وتجيبلي القانون الاساسي
ارجو ان تقبلوني مشاركاً في هذه لكوني مهندس ميكانيك طائرات واحتاج تطوير اختصاصي من خلال دورة بدروس في الهيدروليك Lessons In Hydraulic Systems ولكم جزيل الشكر
