MECHANICAL PROPERTIES OF COMPOSITE LAMINATED DECKS PLATES
A composite material can be defined as a combination of two or more materials that gives better properties than those of the individual components used alone. In contrast to metallic alloys, each material retains its separate chemical, physical, and mechanical properties. The two constituents are reinforcement and a matrix. The main advantages of composite materials are their high strength and stiffness combined with low density when compared to classical materials. Micromechanical approach is found to be more suitable for the analysis of composite materials because it studies the volume proportions of the constituents for the desired lamina stiffness and strength.IJBE-5-2-2017_Elmardi_103_111.pdf (267.4% u)
ما شاء اللهُ!
مجهود طيب؛ في إثراء قسم الهندسة الميكانيكية.
فجزاكم الله تعالى خيرًا؛ أخي المُبارك د. أسامة، وبارك فيكم.
thanks a lot
