[FONT=Arial][CENTER]Solid Converter PDF v3.1 build 437
Solid Converter PDF v3.1 build 437|16.3MB
[COLOR=blue]Convert, create, and extract PDF content, accurately and easily, with Solid Converter PDF. Solid Converter PDF makes your PDF content reusable and recyclable. Convert accurately. Solid Converter PDF creates clean, accurate, easy-to-use PDF conversions. In Microsoft Word you simply open your PDF file, then edit. The text, layout and images of your original document are recovered. Version 3.1 build 437 includes minor bug fixes.
*Convert your PDFs to Microsoft® Word documents for easy editing! Solid Converter PDF to Word converts tables, hyperlinks, rotated text, and more, all at a fraction of the cost of Adobe® Acrobat®.
With our Professional Version you can easily create PDF’s from almost any Microsoft Windows-based program. (As in previous versions, users of the Standard version can create PDFs directly from Microsoft Word.)
*Users can now extract tables from PDF files directly into Excel worksheets to access and re-use data. Users can also open PDF files with tables into Microsoft Word, where each table is handled as a separate object that can be easily changed using Word’s table manipulation features.
*Click a button, create a PDF. It’s that simple.
*Formatting, graphics, page layout, and text flow can be preserved – or not. It’s up to you. Here are some of the ways you can customize your results:
- Page layouts. Preserve page layout elements - including columns and tables - or remove them. Keep only the elements you need.
- Plain text option. If you do not wish to preserve the original fonts, you can choose the Plain Text option.
- Image extraction. You can choose to extract only the images from a PDF document and save them in a graphics file format.
- Page selection. You can also convert only selected pages from a PDF file instead of the entire document.
System Requirements
- Windows® 2000, 2003, or XP
- Microsoft® Word 97, 2000, XP, or 2003 (Office XP or above required for table extraction & optical text recovery.)
- Internet connection required for installing product download.
- Single product license for single system. Site licenses are available.
[/color]
[/font][/center]
[FONT=Simplified Arabic Fixed][COLOR=#0000bb]Password[/color][COLOR=#007700]:[/color][COLOR=#0000bb]FatBuu [/color][/font]
منقول
