Power transmission shafting
Continuous mechanical power is usually transmitted along and between rotating shafts. The transfer between shafts is accomplished by gears, belts, chains or other similar means for matching the torque/speed characteristics of the interconnected shafts - eg. a car needs gears between the engine crankshaft and drive wheel half-shafts. Matching will be examined more closely in later chapters (Squirrel Cage Motors, V-Belt Drives, Spur Gears), here we focus on shafts.
Torque may be transferred to or from the end of one shaft by a second coaxial shaft - this is a pure torque, a twist about the shaft axis. The transfer is accomplished by a shaft coupling (illustrated in the Squirrel Cage Motors chapter) which consists of two often identical half-couplings which are each mounted on one of the shafts before being connected together non-permanently.
The mounting of a half-coupling on a shaft must prevent relative rotation when torque is applied - this is achieved by a positively interlocking element exemplified by a key (or a derivative of this such as a spline) or by friction. Shown here is the free body of a shaft keyed to a coupling half - the torque on the shaft is equilibrated by an equal and opposite torque on the half-coupling. Free bodies of the individual elements clarify how the key’s faces give rise to an equilibrating couple on both the shaft and the half-coupling (refer to the tutorial problems for more details).
The typical friction-based mounting below comprises a split tapered bush which is forced by screws into a mating taper machined in the bore of the half-coupling. The bush contracts onto the shaft causing high pressures and corresponding high surface friction which equilibrates the torque - provided tightening is sufficient.
Torque may be transferred also at any point along a shaft by a gear, belt pulley, or chain sprocket for example, mounted on the shaft as described above. These common elements apply forces offset from the shaft axis, and therefore useful torque T must be accompanied by a corresponding radial load with consequential bending - this is why the generalised shaft design model ( 11) incorporates both torque and bending moment load components.
A spur gear and a belt pulley are sketched, each subjected to loading tangential to its effective or pitch cylinder of diameter D. The load on the spur gear arises from inter-tooth contact with its mating gear and comprises two components - the useful tangential component Ft and the unwanted but unavoidable radial component Fr (commonly 0.36 Ft ). Gear forms other than spur ( see the Spur Gears chapter) give rise also to a load component parallel to the shaft axis - but for all gears, shifting the offset force as above, T = Ft D/2.
A belt, being flexible, cannot withstand compression - the pulley is therefore subjected to two strand tensions Fmax and Fmin both of which must exceed zero. The net torque T = ( Fmax - Fmin ) D/2 is clockwise here. The tension ratio Fmax/Fmin must lie between a lower limit of unity (corresponding to no torque transfer) and an upper limit dictated by incipient belt slip around the pulley. (This may be demonstrated by equally pulling the ends of a bit of rope wrapped around a post, then progressively increasing the pull on one end.) A chain sprocket is similar though the minimum tension may drop to zero due to the positive drive not relying on friction.
The mounting of a half-coupling and the like on a shaft is, locally, intrinsically indeterminate. This is exemplified by the pulley boss illustrated which extends from A to C along the stepped shaft. The actual distributions of bending and torque in the shaft are shown. To the left of A and to the right of C there are no immediate transverse loads, so the bending moment is linear. But within AC the boss contributes to the shaft’s stiffness and also distributes the pulley load gradually into the shaft, so the bending moment variation is non-linear. Similarly the torque is some constant value (zero here) in the shaft to the left of A and another constant value T to the right of C - within AC the torque increases in a complex indeterminate fashion.
No attempt is made to resolve this bending/torsional indeterminacy - the actual distributions are instead replaced by approximate distributions based on external loads concentrated at the mid-point B. This leads to a bending moment diagram characterised by straight segments and a torque diagram which increases stepwise at B. The approximation is justified in view of unknown stiffness details and stress concentration due to shoulders (used for positive longitudinal location) and mountings (square keys, shrink fits etc.) In this example a cross-section between B and C is critical since the diameter is the smaller DA (neglecting the blending radii which reduce stress concentration at the shoulder), the torque is the fully developed T, and the bending moment is to all intents and purposes the peak MB.
Shafts are supported in two bearings (sliding or rolling) which allow the shafts to turn freely - there is no appreciable torque exerted by the bearings. A sliding bearing needs a lubricant film in the clearance space between shaft and bearing bush; in the fully hydrodynamic bearing illustrated the oil is dragged into the wedge-shaped gap causing a pressure build-up (similar to that in hydroplaning) which supports the shaft without metal-to-metal contact and little friction.
A rolling bearing (of which the ball bearing illustrated is but one example) comprises two hardened races between which a number of identical hardened elements roll. Not shown are various necessary details such as means for preventing axial movement of races, for dust sealing and for lubricant retention.
There are many different embodiments of these two bearing classes. A bearing supports a shaft over a finite axial length and so is intrinsically indeterminate no matter what its form - however it is approximated like the boss ABC above by a concentrated reaction at its mid-point.
The transverse forces on a shaft are seldom coplanar, so it is usually necessary to resolve forces into two convenient orthogonal longitudinal planes and to separately consider bending in each. For example the horizontal shaft ABCD, figure (a), is simply supported in bearings at A, D and carries gears or pulleys at B, C.
