Satellite proposed to send solar power to Earth
اليوم غير كل يوم
اليوم لدينا مقاله من شركة ناسا عن قمر صناعيى لارسال طاقة الشمس الى الارض واليكم التفاصيل:
Enlarge
Image credit: John Mankins
B – Artemis Innovation Management Solutions has been given some seed money by NASA to look deeper into a project the company first proposed last summer; namely, building a satellite that could collect energy from the sun and beam it back down to Earth to add to the electrical grid. Building such a satellite has been bantered about for several decades by various groups and scientists, but until now, no one had come up with a design that would work given all the constraints of the time. But now, an idea proposed by longtime NASA engineer John Mankins, now with Artemis, has clearly created enough interest within NASA that some money to investigate the idea is being offered.[/b]
Mankins idea is a bio-mimetic approach, meaning it’s based on the way something in nature goes about handling a similar situation. In this case, it appears that something is the common flower, which uses its petals to collect solar energy. Mankins idea is to build petals out of an array of many small mirrors that would direct sunlight to solar cells. The energy created by the solar cells would then be converted to microwaves which would be broadcast or beamed back to a receiving station on Earth, where electricity (perhaps as much as tens of thousands of megawatts) would be generated from the energy in the microwaves. To make the project feasible, the mirrors and solar cells would be small and lightweight so that they could be easily transported into space using conventional transport vehicles. And because it would be component based, construction costs would be much lower than other proposed ideas.
Enlarge
The project called Solar Power Satellite via Arbitrarily Large PHased Array (SPS-ALPHA) would make use of thin filmed mirrors to reduce weight which would be curved to take maximum advantage of the sunlight it receives. Also, the satellite would sit far enough away from planet Earth so that it would never be in the dark, allowing for a constant stream of microwaves.
The initial seed money is to carry out a feasibility and proof of concept study. If NASA likes what it sees, the next step would likely be the construction of a pared down, cheaper version of the project working from a near Earth orbit. If that works out as planned, than the full scale satellite would be built and sent up, perhaps becoming the game changing solution to energy production that so many researchers the world over have been looking for.
قمر صناعي لإرسال طاقة الشمس إلى الأرض
المركز العلمي للترجمة: حصلت شركة أرتيميس لإدارة الحلول المبتكرة من وكالة الفضاء ناسا على تمويل لبحث في المشروع المقترح من قبل الشركة في الصيف الماضي تحت اسم بناء قمر صناعي لتجميع الطاقة من الشمس وإرسالها إلى الأرض لتضاف إلى شبكة الكهرباء. بناء مثل هذا القمر الصناعي كان مجرد خيال علمي راود عقول الكثير من العلماء لعقود من الزمن، لكن حتى الآن لم يتقدم احد بتصميم يمكن تنفيذه. لكن الآن الفكرة التي طرحها احد مهندسي وكالة الفضاء ناسا John Mankins مع شركة ارتيميس، قد جذبت اهتمام وكالة ناسا لتوفير التمويل اللازم لدراسة إمكانية تنفيذ الفكرة.
فكرة Mankins هي طريقة محاكاة بيولوجية، بمعنى ان الفكرة مستوحاه من الطبيعة وكيف يتم التعامل مع حالة مشابهة. في مثل هذه الحالة، يبدو ان بعض انواع الورود الشائعة تستخدم بتلاتها لتجميع الطاقة الشمسية. فكرة Mankins هي بناء بتلات في صورة مصفوفة من الكثير من المرايا الصغيرة تقوم بتوجيه أشعة الشمس إلى خلايا شمسية. الطاقة الناتجة بواسطة الخلايا الشمسية يمكن تحويلها بعد ذلك إلى أمواج ميكروويف ثم يتم إرسالها في صورة شعاع كهرومغناطيسي الى محطة استقبال على الأرض حيث يمكن توليد طاقة كهربية (قد تصل إلى الأف من الميجا وات) من الطاقة التي تحملها أمواج الميكروويف. ولجعل المشروع قابل للتنفيذ والنجاح يجب ان تكون المرايا والخلايا الشمسية صغيرة وخفيفة الوزن بحيث يمكن نقلها بسهولة إلى الفضاء باستخدام عربات النقل العادية. وبسبب ان المكونات تعتمد على تكاليف البناء فان هذه الفكرة كانت الأقل تكلفة من الأفكار المقترحة الأخرى.
يعرف المشروع باسم Solar Power Satellite via Arbitrarily Large PHased Array ويختصر باسم SPS-ALPHA والذي سوف يعتمد على استخدام أفلام رقيقة للمرايا لتقليل الوزن وسوف تكون منحنية لاستقبال اعلى طاقة شمسية. كذلك سوف يتم تثبيت القمر الصناعي بعيدا عن الكرة الأرضية حتى لا يقع في الظلام، وهذا يسمح بشعاع ميكروويف يصل بثابت إلى الأرض ليلا ونهارا.
التمويل الذي قدمته ناسا هو جزئيا لتقديم دراسة لاثبات نجاح هذه الفكرة. واذا اقنع المشروع ناسا فان الخطوة التالية هي بناء نسخة رخيصة من المشروع لتعمل بالقرب من مدار الأرض. واذا نجحت هذه الخطوة سيتم العمل على تنفيذ المشروع على نطاق واسع وقد يكون في هذا حل لمشاكل إنتاج الطاقة الكهربية والتي بحث عنها العديد من العلماء على مر العقود.
جزاك الله خيرا
شكرا للطرح الطيب
تحياتى
مشكوووووور كتير فنظرية بدون تطبيق تعتبر
نظرية فاشلة نتمنى ان ترى الفكرة النور وتححق
المغذى والمضمون
