[CENTER]هذا هو ضاغط الهواء لغلق غطاء المخرطة
هذا متغير ضغط الهواء او مقياس ضغط الهواء
ساريكم الكنترول وبعد ذلك جميع المفاتيح
Machine Hand WheelControl Penal
اما المفاتيح فكل مفتاح موجود بجوارة وظيفتة
لا تنسونا من دعائكم
A) POWER OFF:
[SIZE=4]
Button for power off CNC controller.
[/size]
B) POWER ON:
[SIZE=4]
Button for power on CNC controller.
[/size]
C) CYCLE START:
[SIZE=4]
Button for cycle start the program.
[/size]
D) FEED HOLD:
[SIZE=4]
Button for hold feed rate or stop machine moving.
[/size]
E) FEED RATE CONTROL:
[SIZE=4]
Switch for feed rate percentage.
[/size]
F) PANEL HAND WHEEL:
[SIZE=4]
X and Z panel hand wheel (For using panel hand wheel please press F1 to switch to panel hand wheel and press +X or -X after that you can use hand wheel to move X-axis, if want to move X-axis press +Z or -Z after that you can move Z-axis by penal hand wheel as well.
[/size]
G) EMERGENCY STOP:
[SIZE=4]
For any emergency condition, press the button to stop all the moving elements immediately.
[/size]
1) PROGRAM EDIT:
[SIZE=4]
Press the button for edit program. (For more info please see Fanuc operator’s manual)
[/size]
