[CENTER]16) WORK LAMP ON/OFF:
Press the key to turn on/off the working lamp. 17) BLOCK SKIP:
Use this function for block skip program. (For more info please see Fanuc operator’s manual) 18) DRY RUN:
Use this function for dry run machine, ignore any feed rate. 19) MACHINE LOCK:
Use this function for lock machine, only run the program, machine did not move. 20) COOLANT AUTO:
Use this function for auto coolant, use M8?M9 code to open/close coolant pump.
21) COOLANT ON:
Use this function for manual coolant pump, press button to open/close coolant pump. 22) To lock the edit program, make people can’t program the code by edit or change it.
23) HANDLE MUTIPLY & RAPID TRAVERSE OVERRIDE:
This button use for hand wheel movement 0.001mm each time or rapid for low speed. 24) HANDLE MUTIPLY & RAPID TRAVERSE OVERRIDE:
This button use for handwheel movement 0.01mm each time or rapid for 25% speed. 25) HANDLE MUTIPLY & RAPID TRAVERSE OVERRIDE:
This button use for handwheel movement 0.1mm each time or rapid for 50% speed.
