Toolroom لماكينة خراطة
(system) #1
[CENTER]26) HANDLE MUTIPLY & RAPID TRAVERSE OVERRIDE:
This button use for handwheel movement 1mm each time or rapid for 100% speed. 27) DISCREASE SPINDLE SPEED:
This button use for discrease spindle speed, each press will discrease 10% of original speed down to 50%. 28) 100% SPINDLE SPEED:
This button use for 100% spindle speed, when you press this button spindle speed will always goes you command run for 100%. 29) INCREASE SPINDLE SPEED:
This button use for increase spindle speed each press will increase 10% of original speed up to 120%. 30) CLOCKWISE SPINDLE:
This button use for clockwise spindle, when left corner red light on telling you spindle clockwise right now. (For lathe machine clockwise spindle should go way when you stand front of machine).
31) STOP SPINDLE:
This button use for stop spindle, when left corner red light on telling you spindle is stop right now. 32) COUNTER CLOCKWISE SPINDLE:
This button use for counter clockwise spindle, when left corner red light on telling you spindle is counter clockwise right now. 33) JOG SPINDLE:
This button use for jog the spindle when you press this button spindle will goes really slowly by clockwise. 34) CUB OIL ALARM:
When left corner red light on, it mean out of oil and please fill some oil in to the cub. 35) CNC ALARM:
When lift corner red light on, it mean the CNC have some problem, press penal key to read massage after finish reading, press reset to remove massage and light. 36) MOTOR ALARM:
When left corner red light on, it mean the motor have some problem , please check it. 37) CHUCK CLOSE:
When left corner red light on, it mean chuck is close, it red light not flash on, if mean chuck is open when chuck open you can’t rotate the spindle.
