اريد المساعده
(رحيق الزهور) #1
احتاح مساعده لفهم برنامج pass 1 & pass2 in assembly لكى احولهم للغه الcبالله عليكم احتاج المساعده علشان اقدم البرنامج قبل نهايه الاسبوع وشكرررررررررررررررا
(hendokasha) #2
طيب ممكن تبعتي الكود بتاع البرنامج يالاسمبلي اصلا لاني بصراحه عنوان الكود غير واضح
(رحيق الزهور) #3
انا معرفش الكود بس البرنامج انا ممكن ابعته انا عاوزه اكتبه بلغه السى[SIZE=2]Pass 1:
begin
…read first input line
if OPCODE = ‘START’ then
begin
…save #[OPERAND] as starting address
…initialize LOCCTR to starting address
…write line to intermediate file
…read next input line
end {if START}
else
…initialize LOCCTR to 0
while OPCODE <> ‘END’ do
begin
if this is not a comment line then
begin
if there is a symbol in the LABEL field then
begin
…search SYMTAB for LABEL
if found then
…set error flag (duplicate symbol)
else
…insert (LABEL, LOCCTR) into SYMTAB
end {if symbol}
…search OPTAB for OPCODE
if found then
…add 3 {instruction length} to LOCCTR
else if OPCODE = ‘WORD’ then
…add 3 to LOCCTR
else if OPCODE = ‘RESW’ then
…add 3 * #[OPERAND] to LOCCTR
else if OPCODE = ‘RESB’ then
…add #[OPERAND] to LOCCTR
else if OPCODE = ‘BYTE’ then
begin
…find length of constant in bytes
…add length to LOCCTR
end {if BYTE}
else
…set error flag (invalid operation code)
end {if not a comment}
end {while not END}
…write last line to intermediate file
…save (LOCCTR - Starting address) as program length
end {Pass 1}
Figure 2.4(a) Algorithm for Pass 1 of assembler. [/size]
[SIZE=2]Pass 2:
begin
…read first input line {from intermediate file}
begin
…write listing line
end {if START}
…write Header record to object program
…initialize first Text record
begin
begin
if found then
begin
if there is a symbol in OPERAND field then
begin
…search SYMTAB for OPERAND
if found then
…store symbol value as operand address
else
begin
…store 0 as operand address
…set error flag (undefined symbol)
end
end {if symbol}
else
…assemble the object code instruction
end {if opcode found}
else if OPCODE = ‘BYTE’ or ‘WORD’ then
…convert constant to object code
if object code will not fit into the current Text record then
begin
…write Text record to object program
…initialize new Text record
end
…add object code to Text record
end {if not comment}
…write listing line
end {while not END}
…write last Text record to object program
…write end record to object program
…write last listing line
end {Pass 2}
انا متشكره على اهتمامك بالموضوع [/size]
(hendokasha) #4
ادخلي علي الموقع ده واعملي بحث هتلاقي اكواد كتير جدا
www.google.com/codesearch
