برنامج للكشف بالكمبيوتر على السيارات الحدثة
(manasrah) #1
اقدم لكم برنامجPCMSCAN 1.4.3وشرحه وكيفية التعامل معه
[size=4][COLOR=#ff0000]
[/color][/size][B][COLOR=blue]PCMSCAN is a fully featured OBD-II scanner and diagnostic tool. It allows viewing, charting, logging and playback of diagnostic data in real time via the vehicle’s OBD-II diagnostic data port. It also allows viewing of vehicle Diagnostic Trouble Codes (DTC’s), Freeze Frame data, and other vehicle information.
PCMSCAN supports 1996 and newer passenger vehicles whether it be US, Asian, or European.
Supported OBD-II protocols: SAE-J1850 (PWM and VPW), ISO-9141, ISO-14230 (KWP2000), and ISO-15765 (CAN).
Download the demo, then if you like it you can and turn your demo into a fully-working version.
Visit the user forum for discussion and information about PCMSCAN, product features, and new releases.
PCMSCAN Features
Virtual Dashboards
Highly configurable realistic looking gauges.
Gauges can be moved, resized, and laid out to resemble your own dashboard.
Virtual dashboard layouts can be loaded and saved from pre-existing templates or your own custom creations.
Gauges can be configured to report the minimum, maximum, and average values of the parameter being monitored.
Highly configurable graphs allow simultaneous graphing of up to 8 parameters per graph.
Tables can be placed on virtual dashboards and customized to report any parameters you want.
Maps can be placed on virtual dashboards and customized to display a full 3D view of any desired parameters.
You can set up an unlimited number of gauges, graphs, tables, and maps on your virtual dashboard. [/color][/b]
Data Logging
Currently supports over 90 generic OBD-II parameters, including O2 sensors.
Also supports all aux. input parameters available from the Innovate Motorsports LM-1 Wide Band O2 meter.
You can record and playback log files in real time (1ms logging accuracy).
You can save and load your log files for offline analysis.
Playback speed can be adjusted to play faster or slower than real time.
There are no restrictions on how much data you can log, it is only limited by how fast your OBD-II interface cable can send the data and by how much memory you have in your computer.
English and Metric (SI) unit measurement systems supported.
Customizable log file data export to .CSV file for easy viewing in other programs like Excel.
Export with real-time stamps for easy correlation with external data logs.
PIDs can be assigned priorities to speed up the data capture rate.
Trouble Codes
Read stored and pending Diagnostic Trouble Codes.
Clear the Check Engine or Service Engine Soon indicator light.
Read and clear stored Freeze Frame data.
Look up trouble code de******ions offline, without needing to connect to a vehicle first.
Test Results
Read the status of Continuously and Non-Continuously Monitored Tests
Miscellaneous
Full support for printing and print preview.
All of the different views, including the virtual dashboards, support printing/print preview.
For those who possess a knowledge of the OBD-II protocol, PCMSCAN provides an OBD-II Terminal where you can send custom commands to the vehicle.
[COLOR=blue][B]Interface Cables
PCMSCAN supports the following OBD-II interface adapters:
Autotap AT1, AT2, AT3, AT123 (v2.x)
VIA LDV100, LDV200, LDV300, LDV123
Multiplex Engineering T16
ELM320, ELM322, ELM323 (v2.x)
ELM327 (all versions)
Any SAE-J2534 compliant OBD-II interface. [/b][/color]
البرنامج هو ادة فحص وتشخيص للسيارت للمهندسين
الحجم : 12 ميغا
http://rapidshare.de/files/31951278/pcm.rar
(manasrah) #2
ان هذا البرنامج من احدى البرامج المستخدمة في فحص السيارات الحديثة بواسطة الكمبيوتر الشخصي وان هذا البرنامج يشمل 75 بالمئة من انواع السيارات حيث ان الوصلة تون اما على شكل usb او على شكل com
وترقبوا برنامج vag com الذي يستخدم في صيانة السيارات الالمانية مثل مرسيدس ، اودي ،bmw ، فولكس فاجن
(khalid1963) #3
اللهم صل على محمد وعلى آل محمد كما صليت على آل ابراهيم إنك حميد مجيد , اللهم بارك على محمد وعلى آل محمد كما باركت على آل ابراهيم إنك حميد مجيد
(khalid1963) #4
السلام عليكم جزاك الله الف خير على البرنامج ولكن اين الكراك
(manasrah) #5
لعيونك يا اخي
Organization: heretic
Product Code: 11111111-11111111-11111111
License Key: CF910193-DC7C0A82-1A6A673E-32A43217-FA022919
(gehad_non_stop) #6
(mohamedradi) #7
Dear brother
the down load in progress thank you
(jovodan) #8
شكرا على البرنامج يا اخي
لكن هل تدلني على الوصلات من اين اشتريها ؟؟
و بكم ؟
(manasrah) #9
اخي الكريم انا اعاني نفس المشكله بالحقيقة هذا برنامج للسيارات ولم اعمل علية وانما اعتمدة لوصف بعض الاشخاص لهذا البرنامج وانا مثلك ابحث عن تلك هي الوصلات ومن اين يمكن الحصول عليها واذا جد جديد سوف تكون اول العارفين
                                               وشكرا
(system) #10
الله يجازيك بألف خير وأكثر نعم المشاركات
(manasrah) #11
اخي الكريم لم اشتري هذه الوصلات وانما بحث عنها في الانترنت فوجدتها وقدمتها بين ايديكم
والله ولي التوفيق
(system) #12
الف شكر على البرنامج الجميييييييييييييييييييييييل
(system) #13
السلام عليكم انا اشكر الاخ صحب الموضوع الجميل والمشاركة الحلوة الوصلة التي تبحثون عنها موجودة بجهاز اسمة لنش صيني الصنع وانا بصدفة وجدت الوصلة التي تصل بالكمبيوتر والسيارة اوبدي 11
يترى موجودة عند باقي وكلاء لاجهزة الصينية وشكرا
(system) #14
(system) #15
شكرا لك يا اخي على هذا البرنامج
(system) #16
يا اخي الكود لم يتم قبوله جزاك الله خير اني في حاجة للبرنامج
(system) #17
gooooooooooooooooooooooooooooooooood
(system) #18
الله يوفقك دنيا واخره ريحتنا بها البرنامج
