ما هي الهندسة الكيميائية و ما هو تاريخها
سلام … الرابط التالي يجيب عن هذان السؤلان … الموقع يحتوي على معلومات أخرى مفيدة …
http://www.pafko.com/history/h_intro.html
شكرا جزيلا
chemical engineering has to do with industrial processes in which raw materials are changed or separated into useful products. The chemical engineer must develop,design , and engineer both the complete process and the equipment used , choose the proper raw materials , operate the plants efficiently, safely , and economically , and see to it that products meet the requirements set by the customers.
chemical engineering is both an art and a science.whenever science helps the engineer to solve a problem , science should be used. When , as is usually the case , science does not give a complete answer , it is necessary to use experience and judgment.The professional stature of an engineer depends on skill in utilizing all sources of information to reach practical solutions to processing problems.
شكرا جزيلا…:slight_smile:
مشكور جدااااااااااااااااااااااااااااااا
شكرا جزيلا
شكرا للك يا اخي علي هل المعلومه الجيده
Thank you for your information, but we want you You provide us with information
In petroleum engineering, and thanks
بارك الله فيك
بارك الله فيك اخي العزيز على الموضوع الرائع
شكراً
salam 3likom
انا كيميائي كيف اتخصص بالهندسة الكيميائية ارجو ان تفيدوني
