دورة تصنيع ربوتات وتحكم فى انظمه الحديثة
المحتوى :
1. Electronic components
· R & C& L measuring & design
· Electronics in low voltage applications & signal processing & audio circuits
· Electronics in high voltage applications& high power
· Types of transistor & How to use
· Applications
· How to control in
- The UJT Transistor -------------------------------------------------- (level1)
- The BJTs Transistor -------------------------------------------------- (level1)
v How to control in Power electronics
- MOSFETs & protection -------------------------------------------------------- (level2)
- The IGBTs Transistor ------------------------------------------------------------ (level2)
- Thyristors (dc & Ac) ----------------------------------------------------------- (level2)
2. Electromechanical machine
· Dc & ac motor
· Dc motor and types----------------------------------------------------------------------- (level1)
· Stepper motor (Unipolar & Bipolar) -------------------------------------------------- (level1)
· Servo motor------------------------------------------------------------------------------- (level2)
· Ac motor----------------------------------------------------------------------------------- (level2)
· Circuit driver for each motor (Low & High current or torque )
· Dc motor diver circuit (speed & direction & braking control) -------------------- (level1)
· Steeper motor circuit control (speed & direction & position control) - ----------- (level1)
· Servo motor control (speed & direction & braking & position control) ---------- (level2)
· How to convert dc motor to servo & self made servo system) -------------------- (level2)
3. Programming
A.
Basics of programming & analysis skills) -------------------------------------- (level1)
Deferent between programming Lang) ----------------------------------------- (level1)
Applications 1 (working with high level system) ----------------------------- (level1)
Visual basic & .net---------------------------------------------------------------- (level1)
Real project with visual basic with interactive program) -------------------- (level1)
vb with PowerPoint
vb with mat lab & lab view
vb with AutoCAD
vb with solid work
Control with vb control in electronics circuit--------------------------------- (level1)
B.
Working with embedded system:
Assemble Lang & MIKRO BASIC Lang ------------------------------------------------ (level1&2)
[ul]
[li]Lexical Elements [/li][li]Program Organization [/li][LIST]
[li]Program Organization [/li][li]Modules [/li][/ul]
[li]Variables [/li][li]Constants [/li][li]Labels [/li][li]Symbols [/li][li]Functions and Procedures [/li][li]Types [/li][ul]
[li]Simple Types [/li][li]Arrays [/li][li]Strings [/li][li]Pointers [/li][/ul]
[li]Operators [/li][li]Expressions [/li][li]Statements [/li][ul]
[li]Introduction to Statements [/li][li]Assignment Statements [/li][li]Conditional Statements [/li][li]Iteration Statements (Loops) [/li][li]Jump Statements [/li][li]asm Statement[/li][/ul]
[/LIST]
4- Interface with Standard System
- Interface with R32 (parallel port)[FONT=&quot] /font
- Interface with USART hardware RS-232 (serial port [FONT=&quot] /font
v Network and interface with Microcontroller & PC
5- Control system & Microcomputers (microcontroller)
Introduction embedded system-------------------------------------------------------------- (level1)
· Micro processors &Processors
· PLCs
· Microcontroller
-Atmel & ARM
-PIC (microchip)
· FPGA
Applications of PIC microcontroller family
· ADC
· PS/2
· PWM
· RS-485 Library
· Software UART Library
· Util Library
· Port Expander
· Conversions Library
· Delays Library
· Math Library
· String Library
- Interface with R32 (parallel port) ------------------------------------------------ (level1)
- Interface with USART hardware RS-232 (serial port) ----------------------- (level2)
- interface with LCD- ----------------------------------------------------------------- (level2)
- Keypad- ------------------------------------------------------------------------------- (level2)
- isolation control circuit & power protection) --------------------------------- (level2)
6. Sensors & Feedback
How to connect signal to microcontroller or any system
How to make & use & calibrate sensors
Limit switch ---------------- (level1)
Light sensors---------------- (level2)
Temperature sensor---------------- (level2)
Color sensors---------------- (level2)
Level sensors---------------- (level2)
Sound sensors---------------- (level2)
Ultrasonic sensors---------------- (level2)
Opto sensors---------------- (level2)
7. Professional PCB Technology
· Toner Transfer Paper------------------------------------------------- (level1)
· Silk screen ----------------------------------------------------------------------------- (level2)
· Spray & sensitive board-------------------------------------------------------------- (level1) A AAAAAAAAADgEAABkcnMvX3JlbHMvZTJvRG9jLnhtbC5yZWxzUEsBAi0AFAAGAAgAAAAhAMTcUXPZ AAAABQEAAA8AAAAAAAAAAAAAAAAAKQUAAGRycy9kb3ducmV2LnhtbFBLAQItAAoAAAAAAAAAIQC7 iU0Oc6oAAHOqAAAVAAAAAAAAAAAAAAAAAC8GAABkcnMvbWVkaWEvaW1hZ2UxLmpwZWdQSwUGAAAA AAYABgB9AQAA1bAAAAAA">
· 8. Design and Simulation
[ul]
[li]Labcenter Electronics Proteuos --------------------------------------------------------- (level1)[/li][/ul]
[ul]
[li]Areas ----------------------------------------------------------------------------------------- (level1)[/li][/ul]
Projects
· 20 deferent Projects in
Robot &
Integrated control system &
Advanced system &
Smart home
Automatic machine
[CENTER]
تفاصيل اكثر
/www.4shared.com/file/68511761/55799b66/Course.html
مثال للمشاريع
http://www.4shared.com/file/68512246…fol_Robot.html
السلام عليكم ورحمة الله
اخي حازم واضح ان الدورة ممتازة ياريت اخي تعيد تحميل الرابط لانه تم حدفه او تطلعنا على مكان وزمان الدورة
الدورة ممتازة اوى
لو ممكن تعيد انزال الرابط مرة اخرى يا هندسة
