انا جديد في المنتدى هنا وياريت لو تساعدوني بخبراتكم
لو سمحت كنت بدور على كتاب ستراكشر يفهمني الحاجات اللي درسناها في اولى وتانيه ونسيناها تاني وحتى لما ذاكرناها كان يادوب بنعرف القوانين وازاي نحل المسائل وبس للاسف
فكنت محتاج كتاب يفهمنا ايه اللي درسته ده والاهم ايه اللي بيمثله في الواقع… يعني مثلا ال roller support ده ايه في الواقع ؟ وايه تطبيقاته وكده
ياريت تقترحو عليا اسمين ولا حاجه لكتب اجنبيه ولو جتبو اللينكات يبقى كتر خيركم
عايزها تغطي الاتي:
STR 101 Structural Analysis
Types of Structures - Members, joints and supports - Analysis of statically determinate beams and frames (stability, equilibrium, reactions, internal forces : normal, shear, and bending moments) - Analysis of statically determinate plane trusses - Analysis of beams subjected to moving loads.
STR 102 Structural Mechanics
Properties of plane sections - Stresses and deformations in axially loaded members - Normal stresses due to axial forces and biaxial moments - Shear stresses in symmetrical solid and hollow sections - Torsion stresses and deformations in circular and non-circular sections -Combined stresses (transformation of stresses, principal shear and normal sresses).
STR 201 Structural Analysis
Deflections (differential equation, energy method, virtual work method)- Influence lines for statically determinate structures - Analysis of statically indeterminate structures by consistent deformation method using matrix formulation - Three moment equation.
STR 203 Structural Mechanics
Normal stresses on composite sections and sections of plane curved beams - Normal streses in elastic and plastic materuials - Shear flow and shear center - Torsion of thin walled tubular members - Shear stresses on unsymmetrical box and multicell sections - Fracture mechanics - Buckling of columns and beam columns.
شكرا
