بعض الاضافات من موقع الشركة
تشرح الاسلوب الجديد للحصول على تلك الطاة الكهربية من وقود الماء
معذرة
لانها باللغة الانكليزية
[ul]
[li]WES generates power from water, producing electricity and heat.[/li][/ul]
[ul]
[li]This safe device can be installed almost anywhere.[/li][li]It can even be installed indoors and underground.[/li][/ul]
[ul]
[li]The system uses no fossil fuel or non-fossil energy in the process of producing electricity and heat from water. Because WES is an independent power source that requires no other outside energy sources, it can be installed in a wide range of locations and does not require establishment of infrastructure.[/li][/ul]
[ul]
[li]1. WES can be installed in transportations including electric vehicles and ships.[/li][li]2. WES can be quickly installed in existing buildings and houses.[/li][li]3. WES can quickly supply power to disaster sites.[/li][/ul]
[IMG]http://www.genepax.co.jp/en/img/wes01.jpg[/IMG] [IMG]http://www.genepax.co.jp/en/img/car01.jpg[/IMG] (1)Water energy system (2)WES-equipped electric car
[B][IMG]http://www.genepax.co.jp/en/img/h3_wes2.jpg[/IMG][/b]
[IMG]http://www.genepax.co.jp/en/img/compare_02.jpg[/IMG]
[ul]
[li]Fossil fuels, such as gases, are used to extract hydrogen.[/li][li]Reformers, which emit CO2, are required to extract the hydrogen.[/li][li]These systems depend on imported resources (fossil fuels).[/li][/ul]
[IMG]http://www.genepax.co.jp/en/img/compare_01.jpg[/IMG]
[ul]
[li]WES uses no fossil fuels and thus emits no CO2.[/li][li]This safe device can be installed almost anywhere[/li] (including indoors and underground).
[li]Energy can be supplied with a stable cost structure that is not influenced by high oil prices.[/li][/ul]
[ul]
[li]Five Major Benefits[/li][/ul]
[B][B]1. Environmental measure[/b][/b]
[ul]
[li]Because no greenhouse gases (such as carbon dioxide and methane) are emitted in the power generation process, introduction of WES contributes to prevention of global warming.[/li][/ul]
2. Safety
[ul]
[li]Water, the source of energy for WES, is safe and non-volatile and is therefore easy to transport and store.[/li][li]This safe device can be installed almost anywhere.[/li][/ul]
3. Emergency response
[ul]
[li]WES can also be used for power generation in emergency situations, including disasters. It is a power generation system for Japan, which has little fossil fuel resources. WES improves safety and protects lives in Japan from the standpoint of supply of energy.[/li][/ul]
4. Makes Japan resource-rich
[ul]
[li]This system requires no imported resources to generate power.[/li][li]Compared with other natural resources, water is relatively evenly distributed throughout the world in overwhelmingly large amounts. Thus, the system has no impact on nature.[/li][/ul]
5. Cost
[ul]
[li]WES is very economical because it does not require a reformer to extract hydrogen or a high-pressure tank to store it.[/li][/ul]
[ul]
[li]Power Generation Features of WES[/li][/ul]
[ul]
[li]WES can continuously and stably generate power because degradation of the electrodes is minimal in the process of extracting electricity from water.[/li][/ul]
[ul]
[li]Cell stack structure[/li][/ul]
[ul]
[li]WES generates high voltage using serially connected layers of single cells.[/li][/ul]
[IMG]http://www.genepax.co.jp/en/img/stack.jpg[/IMG]
[IMG]http://www.genepax.co.jp/en/img/cell.jpg[/IMG]
[ul]
[li]Rechargeable without fossil fuels[/li][/ul]
[ul]
[li]No impact from the high prices of gasoline and diesel oil.[/li][/ul]
[ul]
[li]Continuous recharge is possible with the system mounted in the car[/li][/ul]
[ul]
[li]No infrastructure must be established for recharging.[/li][li]The system can be used as a mobile power generator in the case of a disaster.[/li][/ul]
