كيف ممكن ربط الكمبيوتر مع المايكروكونترولر عن طريق السيريال بورت او ال يو اس بي
وشكرا
وشكرا
Salam Alikom
my brother to connect the microcontroller with the PC you should use serial port communication because the building of the firmware is easy by using visual basic , matlab or labview ( by the way in the next few days ,in shaa allah, I will show u how to make the firmware by using VB6). In the microcontroller side such as PIC16FXXX, you can use high level language such as C++ basic ,…etc and also ,in shaa allah, in the next few days I will post the PICBASIC code to deal with the firmware at the PC (VB6)
Salam Alikom
thnks duude
