أبي حل في برنامج الدكتور جافا او اي برنامج اهم شي الحل احبابي
مطلوب ضروي
1-(Converting feet into meters) Write a program that reads a number in feet, converts it to meters, and displays the result. One foot is 0.305 meters.
2-(Using the &&, || and ^ operators) Write a program that prompts the user to enter an integer and determines whether it is divisible by 5 and 6, whether it is divisible by 5 or 6, and whether it is divisible by 5 or 6, but not both. For example, if your input is 10, the output should be
Is 10 divisible by 5 and 6? false
Is 10 divisible by 5 or 6? true
Is 10 divisible by 5 or 6, but not both? true
من هذا السوال اختار شكلين بس
3-(Printing four patterns using loops) Use nested loops that print the following patterns in four separate programs:
Pattern I Pattern II Pattern III Pattern IV
1 1 2 3 4 5 6 1 1 2 3 4 5 6
1 2 1 2 3 4 5 2 1 1 2 3 4 5
1 2 3 1 2 3 4 3 2 1 1 2 3 4
1 2 3 4 1 2 3 4 3 2 1 1 2 3
1 2 3 4 5 1 2 5 4 3 2 1 1 2
1 2 3 4 5 6 1 6 5 4 3 2 1 1
4-(Finding numbers divisible by 5 and 6) Write a program that displays all the numbers from 100 to 1000, ten per line, that are divisible by 5 and 6.
5-(Analyzing input) Write a program that reads ten numbers, computes their average, and finds out how many numbers are above the average.
لا نقدم هنا حلول ولكن نساعد الاعضاء فى حل المشاكل التى تواجههم
مع الماده كما وردت
