اقدم لكم اليوم الة حاسبة هندسيه رائعه
وخفيفة الوزن
نبذه عنها:
[SIZE=4]
The RPN Engineering Calculator™ (REC) is software that lets you choose between 6 different calculators at the Click of your mouse, and 15 discrete calculators for the more complex functions plus you can write your own programs to solve your most elaborate equations.
This RPN Calculator offers a choice of more than 250 solutions and thousands of conversion possibilities with eight unique keypads. A “Tip of the Day” is displayed when you start the program (it can be turned off), It has a complete help system and individual tips for all but the most ordinary functions. The calculator has a Running Tape Display showing all entries and solutions for each session as well as the operation just performed, or the units (Hz, °, Hy, etc.) of the result.
You can choose between fixed point, scientific, and engineering notation, and select degrees, radians, or grads as the situation requires. Keyboard entry is optional for most of the common functions.
You are able to save the contents of the calculator, the Running Tape Display, the Register Stack, all necessary data required to be able to take up where you left off prior to saving. You can print the contents of the Running Tape Display and you can double-click on any number in the Running Tape Display or the Stack Display to copy it to the x-register.
The RPN Engineering Calculator™ uses an entry register (input window), a working register, referred to as the x-register (x-reg) and a holding register, referred to as the y-register (y-reg), an almost unlimited stack, and 24 storage registers.
واخيرا اليكم رابط التحميل
كلمة السر بالمرفقات
منقول للافاده
[/size]
