هذا كود اخفاء النص خلف الصوره لو تكرمتم اي احد عنده خلفيه يشرحلي هذا الكود
انا طبقته تمام بس المشكله ماني فاهمه كيف الكود هذا يخفي النص خلف الصوره
مثلا لو دخلت كلمة salam
وش يصير للكلمه كيف يتم اخفاءها خلف صوره من نوع jpg
تبع للكود هذا وشاكره لكم حسن تعاونكم
public class stegano
public stegano()
public boolean encode(String path, String original, String ext1, String stegan, String message)
String file_name = image_path(path,original,ext1);
BufferedImage image_orig = getImage(file_name);
BufferedImage image = user_space(image_orig);
image = add_text(image,message);
return(setImage(image,new File(image_path(path,stegan,"png")),"png"));
public String decode(String path, String name)
byte[] decode;
try
BufferedImage image = user_space(getImage(image_path(path,name,"png")));
decode = decode_text(get_byte_data(image));
return(new String(decode));
catch(Exception e)
JOptionPane.showMessageDialog(null,
"There is no hidden message in this image!","Error",
JOptionPane.ERROR_MESSAGE);
return "";
private String image_path(String path, String name, String ext)
return path + "/" + name + "." + ext;
private BufferedImage getImage(String f)
BufferedImage image = null;
File file = new File(f);
try
image = ImageIO.read(file);
catch(Exception ex)
"Image could not be read!","Error",JOptionPane.ERROR_MESSAGE);
return image;
private boolean setImage(BufferedImage image, File file, String ext)
try
file.delete();
ImageIO.write(image,ext,file);
return true;
catch(Exception e)
"File could not be saved!","Error",JOptionPane.ERROR_MESSAGE);
return false;
private BufferedImage add_text(BufferedImage image, String text)
byte img[] = get_byte_data(image);
byte msg[] = text.getBytes();
byte len[] = bit_conversion(msg.length);
try
encode_text(img, len, 0);
encode_text(img, msg, 32);
catch(Exception e)
"Target File cannot hold message!", "Error",JOptionPane.ERROR_MESSAGE);
return image;
private BufferedImage user_space(BufferedImage image)
BufferedImage new_img = new BufferedImage(image.getWidth(), image.getHeight(), BufferedImage.TYPE_3BYTE_BGR);
Graphics2D graphics = new_img.createGraphics();
graphics.drawRenderedImage(image, null);
graphics.dispose();
return new_img;
private byte[] get_byte_data(BufferedImage image)
WritableRaster raster = image.getRaster();
DataBufferByte buffer = (DataBufferByte)raster.getDataBuffer();
return buffer.getData();
private byte[] bit_conversion(int i)
byte byte3 = (byte)((i & 0xFF000000) >>> 24);
byte byte2 = (byte)((i & 0x00FF0000) >>> 16);
byte byte1 = (byte)((i & 0x0000FF00) >>> 8 );
byte byte0 = (byte)((i & 0x000000FF) );
return(new byte[]{byte3,byte2,byte1,byte0});
private byte[] encode_text(byte[] image, byte[] addition, int offset)
if(addition.length + offset > image.length)
throw new IllegalArgumentException("File not long enough!");
for(int i=0; i<addition.length; ++i)
int add = addition[i];
for(int bit=7; bit>=0; --bit, ++offset)
int b = (add >>> bit) & 1;
image[offset] = (byte)((image[offset] & 0xFE) | b );
return image;
private byte[] decode_text(byte[] image)
int length = 0;
int offset = 32;
for(int i=0; i<32; ++i)
length = (length << 1) | (image[i] & 1);
byte[] result = new byte[length];
for(int b=0; b<result.length; ++b )
for(int i=0; i<8; ++i, ++offset)
result[b] = (byte)((result[b] << 1) | (image[offset] & 1));
return result;
