أريد كود يعمل ضغط للصورة باستخدام تقنية ال jpeg
في الماتلاب
وان يكون ابسط من هذا الكود حيث اني لم استطع تشغيل هذا الكود هل يستطيع احد منكم تشغيل هذا الكوذ:
% MATLAB 4.2c JPEG image compression program
% by Scott Teresi, www.teresi.us
% March 15-17, 1997
% Data Classification and Compression class
% Dr. Salari, Univ. of Toledo
% This program compresses an image using the JPEG algorithm
% Enter matlab, then type the name of this file (jpeg) to execute it.
% It requires a ".mat" file containing raw black-and-white image data
% stored in matrix variable "X". The matrix contains the pixel intensities.
% Also, store a colormap in variable "map" (see first few lines of program).
% Initializations
clear % clear all variables from previous sessions
load lenna % load file of variables containing a gray image matrix
orig_img = X; % image matrix was stored in variable X
% image colormap is stored in variable map
quant_multiple = 1; % set the multiplier to change size of quant. levels
% (fractions decrease distortion)
% vary quant_mult from .1 to 3 (see jpeg.results file)
blocksize = 8; % set the size of chunks to take the DCT of ( =< 8)
DCT_quantizer = ... % levels for quantizing the DCT block (8x8 matrix)
[ 16 11 10 16 24 40 51 61; ...
12 12 14 19 26 58 60 55; ...
14 13 16 24 40 57 69 56; ...
14 17 22 29 51 87 80 62; ...
18 22 37 56 68 109 103 77; ...
24 35 55 64 81 104 113 92; ...
49 64 78 87 103 121 120 101; ...
72 92 95 98 112 100 103 99 ];
sz = size(orig_img);
rows = sz(1,1); % finds image's rows and columns
cols = sz(1,2);
colors = max(max(orig_img)); % guess at the number of colors in the image
% Replace a color colormap with a grayscale one
% map_sz = size(map);
% clrs = map_sz(1,1);
% gray_map = (0:clrs-1)' / (clrs-1);
% gray_map = [gray_map gray_map gray_map];
% map = gray_map;
% colormap(map)
% Introduction
str = str2mat( ...
'Scott Teresi, March 1997.', ...
'This program implements the JPEG data compression algorithm.');
ssdisp(0, str);
fprintf (1, 'Image used: lenna.mat
fprintf (1, 'Its size is: %dx%d
', rows, cols);
fprintf (1, 'Number of colors (guess): %d
', colors);
fprintf (1, 'DCT block size: %dx%d
', blocksize, blocksize);
fprintf (1, 'Quant. size multiplier: %d
', quant_multiple);
% Display the original image
figure(1)
image(orig_img)
colormap(map)
title('Original image')
figure(2)
% Prepare image for transform
% Level-shift the image (center intensity values around 0)
orig_img = orig_img - ceil(colors/2);
% Replicate edges of image to make its dimensions a multiple of blocksize
pad_cols = (1 - (cols/blocksize - floor(cols/blocksize))) * blocksize;
if pad_cols == blocksize, pad_cols = 0; end
pad_rows = (1 - (rows/blocksize - floor(rows/blocksize))) * blocksize;
if pad_rows == blocksize, pad_rows = 0; end
for extra_cols = 1:pad_cols
orig_img(1:rows, cols+extra_cols) = orig_img(1:rows, cols);
end
cols = cols + pad_cols; % orig_img is now pad_cols wider
for extra_rows = 1:pad_rows
orig_img(rows+extra_rows, 1:cols) = orig_img(rows, 1:cols);
end
rows = rows + pad_rows; % orig_img is now pad_rows taller
% calculate the DCT transform matrix
% (from page 336 of the Intro to Data Compression book)
i = 0;
for j = 0: blocksize - 1
DCT_trans(i + 1, j + 1) = sqrt(1 / blocksize) ...
* cos ((2 * j + 1) * i * pi / (2 * blocksize));
end
for i = 1: blocksize - 1
DCT_trans(i + 1, j + 1) = sqrt(2 / blocksize) ...
end
end
% Take DCT of blocks of size blocksize
fprintf(1, '
Finding the DCT and quantizing...
starttime = cputime; % "cputime" is an internal cpu time counter
jpeg_img = orig_img - orig_img; % zero the matrix for the compressed image
for row = 1: blocksize: rows
for col = 1: blocksize: cols
% take a block of the image:
DCT_matrix = orig_img(row: row + blocksize-1, col: col + blocksize-1);
% perform the transform operation on the 2-D block
% (from page 331 of the Intro to Data Compression book)
DCT_matrix = DCT_trans * DCT_matrix * DCT_trans';
% quantize it (levels stored in DCT_quantizer matrix):
DCT_matrix = floor (DCT_matrix ...
./ (DCT_quantizer(1:blocksize, 1:blocksize) * quant_multiple) + 0.5);
% place it into the compressed-image matrix:
jpeg_img(row: row + blocksize-1, col: col + blocksize-1) = DCT_matrix;
end
end
fprintf(1, ' CPU time used: %1.3f
', (cputime - starttime))
% Reverse the process (take the Inverse DCT)
fprintf(1, 'Reconstructing quantized values and taking the inverse DCT...
recon_img = orig_img - orig_img; % zero the matrix for the reconstructed image
IDCT_matrix = jpeg_img(row: row + blocksize-1, col: col + blocksize-1);
% reconstruct the quantized values:
IDCT_matrix = IDCT_matrix ...
.* (DCT_quantizer(1:blocksize, 1:blocksize) * quant_multiple);
% perform the inverse DCT:
IDCT_matrix = DCT_trans' * IDCT_matrix * DCT_trans;
% place it into the reconstructed image:
recon_img(row: row + blocksize-1, col: col + blocksize-1) = IDCT_matrix;
end
end
% Restore image to normal
% Level-shift the image back
recon_img = recon_img + ceil(colors/2);
orig_img = orig_img + ceil(colors/2);
% Clip off padded rows and columns
rows = rows - pad_rows;
cols = cols - pad_cols;
recon_img = recon_img(1:rows, 1:cols);
% Display image
colormap(map)
image(recon_img)
title('Decompressed JPEG image')
% Calculate signal-to-noise ratio
fprintf(1, 'Finding the signal-to-noise ratio...
PSNR = 0;
for row = 1:rows
for col = 1:cols
PSNR = PSNR + (orig_img(row, col) - recon_img(row, col)) ^ 2;
end
end
PSNR = 10 * log10 ((255^2) / (1 / (((rows + cols) / 2) ^ 2) * PSNR));
% (averaged rows and cols together)
fprintf(1, '
The signal-to-noise ratio (PSNR) is: %1.3f dB
', PSNR);
وشاكرة لكم تعاونكم
