شرح كل ما يتعلق بالتيربين
(مهندس دولة ميكانيك) #1
[B][CENTER][SIZE=“5”][COLOR=“DarkRed”]بسم الله الرحمن الرحيم
لمن يريد ان يتعرف عن التربين غاز
[/color][/size][/center][/b]
المكونات التيربين
Centrifugal Compressor Operation
Centrifugal compressors rotate ambient air about an impeller. The impeller blades guide the airflow toward the outer perimeter of the compressor assembly. The air velocity is then increased as the rotational speed of the impeller increases
Axial Turbine Operation
(مهندس دولة ميكانيك) #2
Radial Turbine Operation
[CENTER][B][COLOR=“Black”][SIZE=“5”]Same operation characteristics as axial flow turbine.
Radial turbines are simpler in design and less expensive to manufacture.
They are designed much like centrifugal compressors.
Airflow is essentially expanded outward from the center of the turbine.
[/size][/color][/b][/center]
(hiwa 4) #3
مشكوووووووووووورر
