طلب مساعدة
function D = dijkstra(G, pairs)
% This function takes an adjacency matrix called G
% and a p-by-2 matrix called pairs.
% The pairs matrix will contain pairs of indices.
% This function will determine the shortest distance from
% the first index in the pair to the second index for
% every pair in matrix pairs.
% The function will only return a p-by-1 matrix of shortest
% distances. I could use it to also return the shortest path,
% but I don’t need that data, so only shortest distance is
% calculated.
p = size(pairs, 1);  % Number of pairs
v = size(G, 1); % Number of vertices
D = [];
for i = 1:v
    for j = 1:v
        if G(i,j) <= esp
            G(i,j) = inf
        end
    end
end
for i = 1:p
    dist = inf(1, v);
    seen = ones(1, v);
    not_seen = v;
    dist(1, pairs(i,1)) = 0;
    while not_seen > 0
        [distance index] = min(dist .* seen);
        if distance == inf
            break;
        end
        if index == pairs(i,2)
            break;
        end
        seen(index) = inf;
        not_seen = not_seen - 1;
        for n = 1:v
            if seen(n) == 1
                alt = distance + G(index, n);
                if alt < dist(n)
                    dist(n) = alt;
                end
            end
        end
    end
    D = [D ; dist(pairs(i,2))];
end
end
