Autocad 2007 Bible
حجم الكتاب 15.7 ميجا
ويتكون الكتاب من 1296 صفحة
http://www.zshare.net/download/autoc…bible-pdf.html
كتاب للأوتوكاد الاخير 2007
AutoCAD 2007 and AutoCAD LT 2007 Bible
Popular among both novice and experienced AutoCAD users, this comprehensive book begins with an overview of the basics of AutoCAD, such as creating drawings, using commands, and specifying coordinates. Coverage becomes more in-depth as each chapter builds off the previous one, with discussions of 2D and 3D drawing techniques, using layers, creating dimensions, 3D coordinates, and rendering.
صورة:
http://serv2.imagehigh.com/imgss/4151681_1.jpg
TYPE : PDF
LANG : English
PAGE : 1297
Download 13.89 MB
الرابط :
http://rapidshare.de/files/36129349/…2007.and…rar
password:
www.devilived.com
دروس لاوامر الاوتوكاد ثلاثي الابعاد و الاوامر الجديدة في اوتوكاد 2007
http://www.filefactory.com/file/f6fe57
بعد الدخول علي الموقع تضغط:
Download for free with FileFactory Basic
ثم سينقلك لصفحه اخري فتضغط علي:
Click here to begin your download
وسيتم التحميل
مميزاته
AutoCAD 2007 makes the creation, editing, and navigation of solid and surface models simple and intuitive. It brings the power and flexibility of AutoCAD lines, arcs, and circles to cubes, surfaces, and spheres. It enables even an occasional AutoCAD user to quickly and easily create a model of a design. Designers can explore design alternatives with a client, and then, after the contract has been won, reuse that model data as a basis for the drawings needed to build the design.
AutoCAD 2007 introduces the new design “dashboard.” This interface element consolidates all solid and surface modeling tools into a single place and enables users to see at a glance the tools and workflow available in AutoCAD. AutoCAD 2007 also takes the intuitive, grip-based editing features introduced for drafting in previous AutoCAD versions—such as Dynamic Input, ortho, and tracking—and integrates them into solid and surface modeling.
AutoCAD 2007 brings a change to the DWG file format, setting back DWG compatibles yet again. Fortunately Autodesk listened to the demands of users, and included adequate backwards compatibility. AutoCAD 2007 can save as 2004, 2000, and even R14 drawings as well as dxf. In the options dialog you can set the default save format to any of these as well. For the first time, the WBLOCK and REFEDIT commands honor this setting!
