فهرس الموضوع
Manufacturing Processes II
This is the video lecture course about the Manufacturing Processes II
for the Mechanical engineering students. this course cover about the
Machining Forces,Analytical and Experimental , Orthogonal and
Oblique cutting like some more concept for the mechancial engineering
reference . this is very use for the students.
1 - Instructional Objectives - I - Manufacturing Process II
2 - Instructional Objectives - II
3 - On Tool Geometry
4 - Interrelations Among The Tool Angles
5 - Mechanism of Chip Formation
6 - Orthogonal and Oblique Cutting
7 - Use of Chip Breaker in Machining
8 - Machining Forces
9 - Analytical and Experimental
10 - Dynamometers for Measuring Cutting Forces
11 - CTCEAC
12 - CCTCFA
13 - Concept of Machinability and its Improvement
14 - Tool Life
15 - Conventional Cutting Tool Maths
17 - Kinematics System of Centre Lathe
18 - General Purpose Machine Tool Drills
19 - Kinematic Systems and Operations
20 - Configuration and Kinematic System
21 - Mounting of jobs and Cutting Tools in Machine
22 - Mounting of jobs and Cutting Tools in Machine
23a - Construction, Operation and Tool Layout
23b - Use of Attachments In Machine Tools
24 - Forces Developing and Acting In Machine Tools
25 - Estimation of Machining Time
26 - Broaching - Principle Systems and Applications
27 - Grinding Principle and Application
28 - Abrasive Processes
29 - Abrasive Processes (Grinding)
30 - Super finishing Processes
31 - Production of Screw Threads
32 - Gear Manufacturing
33 - Jigs and Fixtures For Machine Shops
34 - Design and Applications of Jigs and Fixtures
35 - Non Traditional Manufacturing
36 - Ultrasonic Machining
37 - Water Jet Machining and Abrasive Water Jet
38 - Electro - Chemical Machining
39 - Electro - Discharge Machining
40 - EBM and LBM
Mechanical Measurements and Metrology
This is the video lecture course about the Mechanical Measurements and
Metrology , this course covery about the Mechanical Measurements,error
in Measurements ,Regression Analysis,Design of Experiments,Temperature
Measurements and having more concept . this is very useful for the
students .
1 - Introduction to the Study of Mechanical Measurement
3 - Errors in Measurement(Contd…)
6 - Regression Analysis (Contd)
8 - Design of Experiments(Contd)
11 - Thermoelectric Thermometry
12 - Thermoelectric Thermometry(Contd)
13 - Measurement of Temperature Under Various Conditions
14 - Errors in Temperature Measurement
15 - Measurement of Transient Temperature and Resistance Thermometry
16 - Resistance Thermometry(Contd)
17 - Resistance Thermometry(Contd)and pyrometry
18 - pyrometry(Contd)
19 - pyrometry(Contd)
20 - Pressure Measurement(Contd)
21 - Pressure Measurement(Contd)
22 - Pressure Measurement(Contd)
23 - Pressure Measurement(Contd)
24 - Transient Response of Pressure Transducers
25 - Transient Response of Pressure Transducers
26 - Measurement of High Vacuum
27 - Measurement of Fluid Velocity
28 - Hot Wire Anemometry and Laser Doppler Velocimetry
29 - Laser Doppler Velocimetry and Ultrasonic Methods
31 - Measurement of Heat Flux(Contd)
32 - Transient Method of Heat Flux Measurement
33 - Measurement of Volume and Mass Flow Rate of Fluid
34 - Flow Measuring Devices[RIGHT]
[/right]
35 - Measurement of Stagnation and Bulk Mean Temperature[RIGHT]
[/right]
36 - Measurement of Thermo-Physical Properties [RIGHT]
[/right]
37 - Measurement of Thermal Conductivity [RIGHT]
[/right]
38 - Measurement of Heat Capacity and Heating Value [RIGHT]
[/right]
39 - Measurement of Viscosity [RIGHT]
[/right]
40 - Measurement of Viscosity(Contd) [RIGHT]
[/right]
41 - Integrating Sphere and Measurement of Emissivity [RIGHT]
[/right]
42 - Measurements of Gas Composition[RIGHT]
[/right]
43 - Measurements of Gas Composition(Contd)
44 - Measurements of Gas Composition and Smoke[RIGHT]
[/right]
45 - Measurement of Force [RIGHT]
[/right]
46 - Force Measurement[RIGHT]
[/right]
47 - Vibration and Acceleration Measurement [RIGHT]
[/right]
48 - Laser Doppler Accelerometer,Speed,Torque
49 -General Issues in Mechanical Measurement
50 - Case Studies
Mechanical Vibrations
[/right]
This is the video course about the Mechanical Vibrations,these video
lecture are covering about the Harmonic and Periodic Motions, Vibration
Terminology,Energy Method,Principle of Virtual work and having more
concept for the engineering students. this is very useful for the
students.
1 - Mod 1 - Lec 1 - Overview of the Course, Practical and Research Trends
2 - Mod 1 - Lec 2 - Harmonic and Periodic Motions, Vibration Terminology
3 - Mod 2 - Lec 1 - Vibration Model, Equation of Motion-Natural Frequency
4 - Mod 2 - Lec 2 - Energy Method, Principle of Virtual Work
5 - Mod 3 - Lec 1 - Viscously Damped Free Vibration Special Cases: Oscillatory
7 - Mod 3 - Lec 3 - Coulomb Damping other Damping Models
8 - Mod 4 - Lec 1 - Forced Harmonic Vibration, Magnification Factor
9 - Mod 4 - Lec 2 - Laplace Transform, Superposition Theorem
10 - Mod 4 - Lec 3 - Rotor Unbalance and Whirling of Shaft, Transmissibility
11 - Mod 4 - Lec 4 - Support Motion, Vibration Isolation
12 - Mod 4 - Lec 5 - Sharpness of Resonance, Vibration Measuring Instruments [RIGHT]
13 - Mod 5 - Lec 1 - Generalized and Principle Coordinates, Derivation of Equation of Motion
14 - Mod 5 - Lec 2 - Lagranges’s Equation
15 - Mod 5 - Lec 3 - Coordinate Coupling
16 - Mod 5 - Lec 4 - Forced Harmonic Vibration
17 - Mod 6 - Lec 1 - Tuned Absorber, Determination of Mass Ratio
18 - Mod 6 - Lec 2 - Tuned and Damped Absorber, Untuned Viscous Damper
19 - Mod 7 - Lec 3 - Modal Analysis: Undamped
20 - Mod 7 - Lec 4 - Modal Analysis: Damped
21 - Mod 8 - Lec 1 - Simple Systems With One Two or Three Discs Geared System
22 - Mod 8 - Lec 2 - Multi-Degree of Freedom Systems-Transfer Matrix Method Branched System
23 - Mod 9 - Lec 1 - Derivation of Equations of Motion Part 1 - Newton’s and Hamilton’s Principle
24 - Mod 9 - Lec 2 - Derivation of Equations of Motion Part 2 - Newton’s and Hamilton’s Principle
25 - Mod 9 - Lec 3 - Vibration of Strings
26 - Mod 9 - Lec 4 - Longitudinal and Torsional Vibration of Rods
27 - Mod 9 - Lec 5 - Transverse Vibration of Beams, Equations of Motion and Boundary Conditions
28 - Mod 9 - Lec 6 - Transverse Vibration of Beams: Natural Frequencies and Mode Shapes
29 - Mod 10 - Lec 1 - Rayleigh’s Energy Method
30 - Mod 10 - Lec 2 - Matrix Iteration Method
31 - Mod 10 - Lec 3 - Durkerley, Rayleigh-Ritz and Galerkin Method
32 - Mod 11 - Lec 1 - Finite Element Formulation for Rods, Gear Train and Branched System
33 - Mod 11 - Lec 2 - Finite Element Formulation for Beams: Galerkin’s Method
34 - Mod 11 - Lec 3 - Global Finite Element Assembly and Imposition of Boundary Conditions
35 - Mod 12 - Lec 1 - Vibration Testing Equipments: Signal Measurements
36 - Mod 12 - Lec 2 - Vibration Testing Equipments: Signal Analysis
37 - Mod 12 - Lec 3 - Field Balancing of Rotors
[RIGHT] Principles of Mechanical Measurements
[/right]
[RIGHT]
[/right]
This is the video lecture course about the Principles of Mechanical
Measurements.this video lecture course are covering about the main
concept of the mechanical measurements. this is very useful for the
mechancial engineering students.
1 - Principles Of Mechanical Measurements
2 - Principles Of Mechanical Measurements
3 - Principles Of Mechanical Measurements
4 - Principles Of Mechanical Measurements
5 - Principles Of Mechanical Measurements
6 - Principles Of Mechanical Measurements
7 - Principles Of Mechanical Measurements
8 - Principles Of Mechanical Measurements
9 - Principles Of Mechanical Measurements
10 - Principles of Mechanical Measurements
11 - Principles Of Mechanical Measurements
12 - Principles Of Mechanical Measurements
13 - Principles Of Mechanical Measurements
14 - Principles Of Mechanical Measurements
15 - Principles Of Mechanical Measurements
16 - Principles Of Mechanical Measurements
17 - Principles Of Mechanical Measurements
18 - Principles Of Mechanical Measurements
19 - Principles Of Mechanical Measurements
20 - Principles Of Mechanical Measurements
21 - Principles Of Mechanical Measurements
22 - Principles Of Mechanical Measurements
23 - Principles Of Mechanical Measurements
24 - Principles Of Mechanical Measurements
25 - Principles Of Mechanical Measurements
[RIGHT] Manufacturing Processes I
[/right]
for the mechanical engineering student. this course have about the
Powder Metallurgy ,Metal Forming fundamentals,swaging & wire Drawing
as well as it 's also cover some more concept. this is very useful for the
mechanical engineering students.
1 - Mod 1 - Lec 1 Powder Metallurgy - 1
2 - Mod 1 - Lec 2 Powder Metallurgy - 2
3 - Mod 1 - Lec 3 Powder Metallurgy - 3
4 - Mod 1 - Lec 4 Metal Forming - Fundamentals
6 - Mod 1 - Lec 6 Swaging & Wire Drawing
7 - Mod 1 - Lec 7 Sheet Metal Operations
8 - Mod 1 - Lec 8 Sheet Metal Operations - 2
9 - Mod 1 - Lec 9 Sheet Metal Operations - 3
10 - Mod 1 - Lec 10 Sheet Metal Working - Presses
11 -Mod 1 - Lec 11 Sheet Metal Working - Equipment
12 - Mod 1 - Lec 12 High Energy Rate Forming Processes
13 - Mod 1 - Lec 13 Machining Fundamentals
14 - Mod 1 - Lec 14 Machining - I
15 - Mod 1 - Lec 15 Machining - II
16 - Mod 1 - Lec 16 Machining - III
17 - Mod 2 - Lec 1 Metal casting
18 - Mod 2 - Lec 2 Metal casting
19 - Mod 2 - Lec 3 Metal Casting
20 - Mod 2 - Lec 4 Metal Casting
21 - Mod 2 - Lec 5 Metal Casting
22 - Mod 2 - Lec 6 Metal Casting
23 - Mod 2 - Lec 7 Metal Casting
24 - Mod 2 - Lec 8 Metal Casting
25 - Mod 2 - Lec 9 Metal Casting
26 - Mod 2 - Lec 10 Metal Casting
27 - Mod 3 - Lec 1 Introduction
28 - Mod 3 - Lec 2 Welding Process Classification
29 - Mod 3 - Lec 3 Brazing Soldering & Braze Welding
30 - Mod 3 - Lec 4 Arc Welding Power Source Part - 1
31 -Mod 3 - Lec 5 Arc Welding Power Source Part - 2
32 - Mod 3 - Lec 6 Shielded Metal Arc Welding Part - 1
33 - Mod 3 - Lec 7 Shielded Metal Arc Welding Part - 2
34 - Mod 3 - Lec 8 Submerged Arc Welding
35 - Mod 3 - Lec 9 Gas Metal Arc Welding
36 - Mod 3 - Lec 10 Gas Metal Arc Welding
37 - Mod 3 - Lec 11 Tungsten Inert Gas Welding Part - 1
38 - Mod 3 - Lec 12 Tungsten Inert Gas Welding Part - 2
39 - Mod 3 - Lec 13 Resistance Welding Process
40 - Mod 3 - Lec 14 Reaction in Weld Region & Welding Defects
[RIGHT] Kinematics of Machines
[/right]
This is a video lecture course about the Kinematics of Machines. this is giving the detail Kinematics of Machines. this video lecture course are very useful for the mechanical Engineering students.
1 - Module 1 - Lecture 1
10 - Module 3 - Lecture 4
11 - Module 4 - Lecture 1
12 - Module 4 - Lecture 2
13 - Module 5 - Lecture 1
14 - Module 5 - Lecture 2
15 - Module 5 - Lecture 3
16 - Module 6 - Lecture 1
17 - Module 6 - Lecture 2
18 - Module 6 - Lecture 3
19 - Module 7 - Lecture 1
20 - Module 7 - Lecture 2
21 - Module 7 - Lecture 3
22 - Module 8 - Lecture 1
23 - Module 8 - Lecture 2
24 - Module 9 - Lecture 1
25 - Module 9 - Lecture 2
26 - Module 9 - Lecture 3
27 - Module 9 - Lecture 4
Advanced Materials and Processes
This Video Lecture course about the Advanced Materials and Processes. this course are covering the Amorphous materials,Structure of Materials,Nano Crystalline
Materials,Quasicrystals video lecture as well as having some more concept of video course for the Electircal student with easy of understand video lecture cours
1 - Structure of Materials Part - I
2 - Structure of Materials Part - II
3 - Nano Crystalline Materials Part - I
4 - Nano Crystalline Materials Part - II
5 - Nano Crystalline Materials Part - III
6 - Nano Crystalline Materials Part - IV
7 - Amorphous Materials Part - I
8 - Amorphous Materials Part - II
9 - Amorphous Materials Part - III
10 - Amorphous Materials Part - IV
11 - Amorphous Materials Part - V
12 - Quasicrystals Part - I
13 - Quasicrystals Part - II
14 - Nano Quasicrystals Part - I
15 - Nano Quasicrystals Part - II
16 - Rapid Solidification Processing
17 - Mechanical Alloying
18 - Advanced AI Alloys Part - I
19 - Advanced AI Alloys Part - II
20 - Advanced AI Alloys Part - III
21 - Advanced AI Alloys Part - IV and Ti Alloys
22 - Shape Memory Alloys
23 - Strengthening Mechanisms Part - I
24 - Strengthening Mechanisms Part - I
25 - Superalloys
26 - In-Situ Composites Part - I
[RIGHT] Project and Production Management
[/right]
These is the video lecture course about the Project and Production
Management . these video lecture course are covering about the
Project selection,Overview of Project Management, Basic Scheduling and
also covering the main concept of the project management well and
good for the students.
1 - Project and Production Management - An Overview
2 - Project Management: An Overview
3 - Project Identification and Screening
8 - Consistency and Redundancy in Project Networks
9 - Basic scheduling with A-O-A Networks
10 - Basic Scheduling with A-O-N Networks
11 - Project Scheduling with Probabilistic Activity
12 - Linear Time-Cost Tradeoffs in Projects
13 - Project Crashing with Multiple Objectives
14 - Resource Profiles and Leveling
15 - Limited Resource Allocation
16 - Project Monitoring and Control with PERT/Cost
17 - Team Building and Leadership in Projects
18 - Organizational and Behavioral Issues
19 - Computers in Project Management
20 - Project Completion and Review
21 - Life Cycle of a Production System
22 - Role of Models in Production Management
23 - Financial Evaluation of capital Decisions
24 - Decision Trees and Risk Evaluation
25 - Introducing New Products & Services [RIGHT]
[/right]
26 - Economic Evaluation of New Products & Services
29 - Issues in Location of Facilities
30 - Mathematical Models for Facility Location
31 - Layout planning
32 - Computerised Layout Planning
33 - Product Layouts and Assembly Line Balancing
34 - Forecasting
35 - The Analysis of Time Series
36 - Aggregate Production Planning: Basic Concepts
37 - Modelling Approaches
38 - Basic Inventory Principles
39 - Inventory Modelling
40 - Material Requirements Planning
[RIGHT] Refrigeration and Air Conditioning
This is the video course about the Refrigeration and Air Conditioning . this video lecture are covering about the history of Refrigeration
,Air Cycle Refrigeration systems, Methods of Producing low Transfer and having more vidoe lecture for the students.
[/right]
2 - Refrigerant Compressors & Development
4 - Review of Fundamentals Thermodynamics - I
6 - Fundamentals of Fluid Flow
7 - Fundamentals of Heat Transfer
8 - Methods of Producing low Temperatures
9 - Air Cycle Refrigeration Systems
10 - Vapour Compression Refrigeration Systems
11 - Vapour Compression Refrigeration Systems (Contd.)
12 - Vapour Compression Refrigeration Systems (Contd.)
13 - Vapour Compression Refrigeration Systems (Contd.)
14 - Vapour Absorption Refrigeration Systems
15 -Vapour Absorption Refrigeration System
16 - Vapour Absorption Refrigeration Systems (Contd.)
17 - Vapour Absorption Refrigeration Systems (Contd.)
20 - Refrigeration System Components : Compressor
21 - Refrigeration System Components : Compressor (Contd.)
22 - Refrigeration System Components : Compressor (Contd.)
23 - Refrigeration System Components : Compressor (Contd.)
24 - Refrigeration System Components : Compressor (Contd.)
25 - Refrigeration System Components : Compressor (Contd.)
26 - Refrigeration System Components : Condensers
27 - Refrigeration System Components : Condensers (Contd.)
28 - Refrigeration System Components : Evaporators
29 - Refrigeration System Components : Evaporators
30 - Refrigeration System Components : Expansion Devices
31 - Refrigeration System Components : Expansion Devices
32 - Analysis of Complete Vapour Compression System
33 - Refrigerants
34 - Psychrometry
36 - Inside Design Condition Thermal Comfort
37 - Psychrometry of Air Conditioning Systems
39 - Cooling and Heating Load Calculation : Solar Radiation
40 - Cooling and Heating Load Calculations
41 - Cooling and Heating Load Calculations (Contd.)
42 - Cooling and Heating Load Calculations (Contd.)
43 - Selection of Air Conditioning Systems
44 - Transmission and Distribution of Air
45 - Transmission and Distribution of Air (Contd)
[RIGHT] Strength of Materials
This is the Video Lecture course about the Strength of Materials. This vieo lecure course are covering about the Solid Mechanics,
Strength of Materials and having more details lecture about these concpet for the students
[/right]
1 - Solid Mechanics
2 - Strength of Materials
3 - Strength of Materials
4 - Solid Mechanics
5 - Strength of Materials
6 - Strength of Materials
7 - Strength of Materials
8 - Strength of Materials
9 - Strength of Materials
10 - Strength of Materials
11 - Strength of Materials
12 - Strength of Materials
13 - Strength of Materials
14 - Strength of Materials
15 - Strength of Materials
16 - Strength of Materials
17 - Strength of Materials
18 - Strength of Materials
19 - Strength of Materials
20 - Strength of Materials
21 - Strength of Materials
22 - Strength of Materials
23 - Strength of Materials
24 - Strength of Materials
25 - Strength of Materials
26 - Strength of Materials
27 - Strength of Materials
28 - Strength of Materials
29 - Strength of Materials
30 - Strength of Materials
31 - Strength of Materials
32 - Strength of Materials
33 - Strength of Materials
34 - Strength of Materials
35 - Strength of Materials
36 - Strength of Materials
37 - Strength of Materials
38 - Strength of Materials
39 - Strength of Materials
40 - Strength of Materials
[RIGHT] Introduction to Finite Element Method
[/right]
[RIGHT]
[/right]
This is a video lecture course about the Introuduction to Finite Element
Method. this is giving the detail introuduction about the Finite Element
Method. this video lecture course are very useful for the mechanical
1 - Introduction to Finite Element Method
2 - Introduction to Finite Element Method
3 - Introduction to Finite Element Method
4 - Introduction to Finite Element Method
5 - Introduction to Finite Element Method
6 - Introduction to Finite Element Method
7 - Introduction to Finite Element Method
8 - Introduction to Finite Element Method
9 - Introduction to Finite Element Method
10 - Introduction to Finite Element Method
11 - Introduction to Finite Element Method
12 - Introduction to Finite Element Method
13 - Introduction to Finite Element Method
14 - Introduction to Finite Element Method
15 - Introduction to Finite Element Method
16 -Introduction to Finite Element Method
17 - Introduction to Finite Element Method
18 - Introduction to Finite Element Method
19 - Introduction to Finite Element Method
20 - Introduction to Finite Element Method
21 - Introduction to Finite Element Method
22 - Introduction to Finite Element Method
23 - Introduction to Finite Element Method
24 -Introduction to Finite Element Method
25 - Introduction to Finite Element Method
26 - Introduction to Finite Element Method
27 - Introduction to Finite Element Method
28 - Introduction to Finite Element Method
29 - Introduction to Finite Element Method
30 - Introduction to Finite Element Method
31 - Introduction to Finite Element Method
32 - Introduction to Finite Element Method
[RIGHT] Advanced Finite Elements Analysis
[/right]
This is the video course about the Advanced Finite Elements Analysis
from the Indian Institute of Technology . The Mechanical Engineering
Students can use this video course to understand about the concept
of the Advanced Finite Elements Analysis.
1 - Advanced Finite Elements Analysis
2 - Advanced Finite Elements Analysis
3 - Advanced Finite Elements Analysis
4 - Advanced Finite Elements Analysis
5 - Advanced Finite Elements Analysis
6 - Advanced Finite Elements Analysis
7 - Advanced Finite Elements Analysis
8 - Advanced Finite Elements Analysis[RIGHT]
[/right]
9 - Advanced Finite Elements Analysis
10 - Advanced Finite Elements Analysis
11 - Advanced Finite Elements Analysis
12 - Advanced Finite Elements Analysis
13 - Advanced Finite Elements Analysis
14 - Advanced Finite Elements Analysis
15 - Advanced Finite Elements Analysis
16 - Advanced Finite Elements Analysis
17 - Advanced Finite Elements Analysis
18 - Advanced Finite Elements Analysis
19 - Advanced Finite Elements Analysis
20 - Advanced Finite Elements Analysis
21 - Advanced Finite Elements Analysis
22 - Advanced Finite Elements Analysis
23 - Advanced Finite Elements Analysis
24 - Advanced Finite Elements Analysis
25 - Advanced Finite Elements Analysis
26 - Advanced Finite Elements Analysis
27 - Advanced Finite Elements Analysis
28 - Advanced Finite Elements Analysis
[RIGHT] Advanced Operations Research
[/right]
This is the video course about the Advanced Operations Research for
the Mechanical Engineering students.this course are covering so many
concept something like Primal-Dual Algorithm,Complexity of Simplex Algorithm and touching many more subject.
1 - Introduction and Linear Programming
3 - Simplex Method for Bounded Variables
4 - One Dimensional Cutting Stock Problem
5 - One Dimensional Cutting Stock Problem (Contd)
6 - Dantzig-Wolfe Decomposition Algorithm
7 - Dantzig-Wolfe Decomposition Algorithm Primal-Dual Algorithm
8 - Primal-Dual Algorithm [RIGHT]
[/right]
9 - Goal Programming-Formulations
10 - Goal Programming Solutions Complexity of Simplex Algorithm
11 - Complexity of Simplex Algorithm (Contd) Integer Programming
12 - Integer Programming-Formulations
13 - Solving Zero-One Problems
14 - Solving Zero-One Problems (Contd)
15 - Branch And Bond Algorithm For Integer Programming
17 - All Integer Primal Algorithm
18 - All Integer Dual Algorithm
19 - Network Models
21 - Successive Shortest Path Problem
22 - Maximum Flow Problem
23 - Minimum Cost Flow Problem
24 - Traveling Salesman Problem (TSP)
25 - Branch and Bound Algorithms for TSP
26 - Heuristics for TSP
27 - Heuristics for TSP (Contd)
30 - Queueing Models
31 - Single Server Queueing Models
32 - Multiple Server Queueing Models
33 - Game Theory
34 - Critical Path Method
[RIGHT] Advanced Strength of Materials
[/right]
This is the video course about the Advanced Strength of Materials for
the mechanical Engineering students. this course cover about the
Stress and Strain Tensor, Transformation of stresses and Mohr circle,
calculation of principal stresses as well as Equilibrium Equations and having
many more subject . [RIGHT]
[/right]
1 - Stress and Strain Tensor
2 - Stress and Strain Tensor (Continued) and Cauchy Formula for Traction
3 - Examples on Calculation of Strains and Tractions, Principal Stresses and Directions
5 - Maximum Shear Stress and Octahedral Shear Stress, Deviatoric and Hydrostatic Stresses
6 - Transformation of Stresses and Mohr Circle in 3-D
8 - Deformation, Rotation and Strain Tensors, Principal Strains,Deviatoric and Hydrostatic Strains
9 - Strain Transformations, Strains in Polar Coordinates, Equilibrium Equations in 2-D
10 -Equilibrium Equations in 2-D Polar Coordinates Plane Stress and Plane Strain Conditions
12 - Relation between Elastic Constants and Strain Energy Densities Recap of Lectures 1 to 11.
13 - Stress Distribution in Thick Cylinder
14 - Stresses due to Shrink Fitting
15 - Stresses in Rotating Disc
16 - Examples on Shrink Fitting and Rotating Disc
17 - Torsion of Non-Circular Shaft
18 - Torsion of Non-Circular Shaft (Continued)
19 - Membrane Analogy for Torsion
20 - Torsion of Thin Box Sections
21 - Torsion of Box and Open Sections
23 - Bending of Curved Bars (Continued)
24 - Theories of Failure
25 - Theories of Failure (Continued)
26 - Theories of Failure (Continued) and Their Applications, Griffith Theory of Brittle Fracture
29 - Theorems of Elasticity (Continued)
30 - Thermal Stress Distribution in Rectangular Sheet due to Symmetric and Asymmetric Temperature Fields
31 - Thermal Stress Distribution in Cylinders
32 - Unsymmetrical Bending.
33 - Shear Centre
34 - Plate Bending
35 - Plate Bending (Continued)
36 - Examples on Plate Bending
37 - Approximate Solutions for Bending of Rectangular and Circular Plates
38 - Thin Shells of Revolution
39 - Beam on Elastic Foundation
[RIGHT] Basic Thermodynamics
[/right]
This is teh Basic Thermodynamics for the mechanical engineering student
and this video course are covering many more subject something like
zeroth law and fundamental concepts and Lecture about the Laws , Vapors
Powers and many more subject . this is very useful for the mechanical
1 - Introduction and Fundamental Concepts
2 - Zeroth Law and Fundamental Concepts
3 - Different Kind of Energy and First Low-I
4 - First Low - II [RIGHT]
[/right]
5 - First Low - III [RIGHT]
[/right]
6 - Second Law and Its Corollaries - I
7 - Second Law and Its Corollaries - II
8 - Second Law and Its Corollaries - III
9 - Second Law and Its Corollaries - IV
10 - Second Law and Available Energy - I
11 - Second Law and Available Energy - II
12 - Second Law and Available Energy - III
13 - Thermodynamic Property Relations - I
14 - Thermodynamic Property Relations - II
15 - Joule-Kelvin Expansion: Properties of Pure Substances
16 - Properties of Pure Substances - I
17 - Properties of Pure Substances - II
18 - Properties of Pure Substances: Ideal Gases
19 - Properties of Ideal Gases
24 - Gas Power Cycle - I
25 - Gas Power Cycle - II
27 - Thermodynamics of Reacting System - I
28 - Thermodynamics of Reacting System-II
29 - Thermodynamics of Reacting System-III
30 - Thermodynamics of Multi Component System-I
31 - Thermodynamics of Multi Component System-II
32 - Thermodynamics of Multi Component System-III
[RIGHT] Computer Aided Design and Manufacturing
[/right]
This video course are covering about the Computer Aided Design subject
and this video lecture are having good lecture in many more concept
something like 2D Transformations,3D Transformations and Projection
Raster Graphics like that.
1 - An Introduction to CAD
2 - Input Output Devices, Raster Graphics
5 - Polygon Filling
9 - 3D Transformations and Projection
11 - Projections and Hidden Surface Removal
15 - Finite Element Method : An Introduction
16 - Galerkin’s Approach
17 - Galerkin’s Method : 1D Finite Element Method
18 - 1D Finite Element Problems
19 - 1D Finite Element Problems
20 - FE Problems : Solving for Q
21 - 1D - FE Problems : Galerkin’s Approach
22 - Penalty Approach and Multi Point Boundary
23 - Quadratic Shape Functions
24 - 2D - FE Problems
26 - 2D - FE Problems (Contd.)
27 - 3D - FE Problems
28 - 3D - Tetrahedral and 2D - Quadrilateral Element
29 - Mesh Preparation
30 - Modeling of Curves
31 - Modeling of Curves
32 - Modeling of Curves
33 - Modeling of B-Spline Curves
34 - Modeling of B-spline Curves
35 - Surface Modeling
36 - Surface Modeling
37 - Display of Curves and Surfaces
38 - Solid Modeling
39 - Solid Modeling
40 - Solid Modeling Using Octrees
42 - Computer Aided Manufacturing
43 - What is CAD/CAM
44 - An Overview of Geometric Modeling
47 - B-Spline Curve
48 - Parametric Surfaces - Part-1
49 - Parametric Surfaces - Part-2
50 - Solid Modeling
51 - Geometric & Product Data Exchange
52 - Reverse Engineering
[RIGHT] Design of Machine Elements I
[/right]
This video lecture course about the Design of Machine Elements . this
course are covering many main subject like simple stresses in machine
Elements, Design for Strength and having many more subject for the
student.
1 - Design Philosophy
5 - Simple Stresses In Machine Elements
6 - Simple Stresses In Machine Elements
7 - Compound Stresses In Machine Elements
10 - Design For Strength
11 - Design for Strength
12 - Design for Strength
15 - Design Of Keys and Splines
16 - Threaded Fasteners
17 - Design Of Threaded Fasteners
18 - Power Screws
20 - Shaft Coupling - I
21 - Shaft Coupling - II
22 - Rivet Joints
23 - Design of Welded Joints - I
24 - Design of Welded Joints - II
25 - Design of Joints With Eccentric Loading
26 - Design of Joints With Variable Loading
27 - Design of Springs
28 - Design Of Springs
29 - Design Of Springs
30 - Belt Drives
31 - Belt Drives
32 - Belt Drives
33 - Design for Strength
34 - Design of Shafts
35 - Design of Machine Elements - I (V & W)
36 -Design of Machine Elements ( V & W )
37 - Design of Cylinders & Pressure Vessels - II
38 - Design of Cylinders & Pressure Vessels - III
39 - Design of Brakes - I
[RIGHT] Dynamics of Machines
[/right]
This video course about the Dynamics of Machines for the mechanical
Engineering Students.this course covers Dynamic Force Analysis of
Mechanisms, Inertia Tensor & Angular Momentum,Gyroscopic Action in Machines , Rotary Balancing and covering some more subject well and good .
1 - Module 1 - Lecture 1 - Rigid Body Motion
2 - Module 1 - Lecture 2 - Rigid Body Motion
3 - Module 1 - Lecture 3 - Dynamic Force Analysis of Mechanisms
4 - Module 2 - Lecture 1 -Space Motion of Rigid Bodies
5 - Module 2 - Lecture 2 - Inertia Tensor & Angular Momentum
6 - Module 2 - Lecture 3 - Euler’s Equation of Motion
7 - Module 2 - Lecture 4 - Gyroscopic Action in Machines
8 - Module 3 - Lecture 1 - Unbalance in Machines
9 - Module 3 - Lecture 2 - Rotary Balancing
10 - Module 3 - Lecture 3 - Balancing Machines
11 - Module 3 - Lecture 4 - Field Balancing of Rotors
12 - Module 4 - Lecture 2 - Single-Cylinder Engine Balancing
13 - Module 4 - Lecture 1 - Balancing of Single Slider Machines
14 - Module 4 - Lecture 3 - In-Line Engine Balancing
15 - Module 5 - Lecture 1 - V & Radial Engine Balancing
16 - Module 6 - Lecture 1 - Turning Moment Diagram
17 - Module 6 - Lecture 2 - Flywheel Analysis
18 - Module 7 - Lecture 1 - Dynamics of Machines
19 - Module 7 - Lecture 2 - Dynamics of Machines
20 - Module 7 - Lecture 3 - Dynamics of Machines
21 - Module 8 - Lecture 1 - Dynamics of Machines
22 - Module 8 - Lecture 2 - Dynamics of Machines
23 - Module 8 - Lecture 3 - Dynamics of Machines
24 - Module 9 - Lecture 1 - Dynamics of Machines
25 - Module 9 - Lecture 2 - Dynamics of Machines
26 - Module 10 - Lecture 1 - Dynamics of Machines
27 - Module 10 - Lecture 2 - Dynamics of Machines
28 - Module 11 - Lecture 1 - Dynamics of Machines
29 - Module 11 - Lecture 2 - Rotating Vector Approach
30 - Module 11 - Lecture 3 - Equivalent viscous damping
31 - Module 11 - Lecture 4 - Dynamics of Machines
32 - Module 12 - Lecture 1 - Systems with two degree of freedom
33 - Module 12 - Lecture 2 - Tuned Vibration Absorber
34 - Module 12 - Lecture 3 - Design of Vibration Absorbers
35 - Module 12 - Lecture 4 - Flexibility Matrix & Influence Coeff
36 - Module 12 - Lecture 5 - Forced Vibration of multiple
37 - Module 12 - Lecture 6 - Forced Vibration of Multiple degrees
38 - Module 13 - Lecture 1 - Vibration of Continuous Systems
39 - Module 13 - Lecture 2 - Vibration of Continuous Systems
40 - Module 13 - Lecture 3 - Vibration of Beams
41 - Module 13 - Lecture 4 - Rayleigh’s method
42 - Module 13 - Lecture 5 - Rayleigh-Ritz Method
43 - Module 14 - Lecture 1 - Vibration Measurement
44 - Module 14 - Lecture 2 - Vibration Measurement Types of Pickups
[RIGHT] Engineering Mechanics
[/right]
This is the video course about the Enineering Mechanis . this video
lecture are cover about Fundamentals of Engineering Mechanics ,
Equations of Equilibrium,Truss Analysis and having more subject video lecture
course are having under the mechanical engineering .
1 - Mod 1 - Lec 1 - Fundamentals Of Engineering Mechanics
2 - Mod 1 - Lec 2 - Equations of Equilibrium[RIGHT]
[/right]
3 - Mod 2 - Lec 4 - Truss Analysis Part - 2
4 - Mod 2 - Lec 5 - Analysis of Frames & Machines
5 - Mod 3 - Lec 6 - Internal Forces
6 - Mod 3 - Lec 7 - Internal Forces in Beams
8 - Mod 4 - Lec 9 - Friction[RIGHT]
[/right]
9 - Mod 4 - Lec 10 - Application of Friction Part - 1
10 - Mod 4 - Lec 11 - Application of Friction Part - 2
11 - Mod 5 - Lec 12 - Application of Friction Part - 3
12 -Mod 6 - Lec 13 - Centroids & Center of Mass
13 - Mod 6 - Lec 14 - Centroids & Area of Moments
14 - Mod 6 - Lec 15 - Product of Inertia, Rotation of Axis and Principle Moments of Inertia
15 - Mod 7 - Lec 16 - Second Moment of Mass
16 - Mod 8 - Lec 18 - Principle of Virtual Work
17 - Mod 8 - Lec 20 - Systems with Friction
18 - Mod 9 - Lec 21 - Potential Energy
19 - Mod 9 - Lec 22 - Stability of Equilibrium
20 - Mod 10 - Lec 23 - Kinematics of a Particles
21 -Mod 10 - Lec 24 - Kinematics of a Particle Moving on a Curve
22 - Mod 10 - Lec 25 - Relative Motion
23 - Mod 10 - Lec 26 - Plane Kinematics of Rigid Bodies
24 - Mod 11 - Lec 27 - Kinematics of a Particle
25 - Mod 11 - Lec 28 - Work and Enjoy
26 - Mod 11 - Lec 29 - Impulse and Momentum
27 - Mod 11 - Lec 30 - Direct and Oblique Impulse
28 - Mod 11 - Lec 31 - Plane Kinetics of Rigid Bodies
29 - Mod 12 - Lec 32 - Kinetics of a Body
30 - Mod 12 - Lec 33 - Method of Momentum and Analysis of Robot Manipulator
31 - Mod 13 - Lec 34 - Kinematics in 3D
32 - Mod 14 - Lec 35 - Kinetics in 3D
33 -Mod 15 - Lec 36 - Free Vibration
34 - Mod 15 - Lec 37 - Forced Vibration (Damped Undamped)
35 - Mod 15 - Lec 38 - Vibration of Rigid Bodies Part - 1
36 - Mod 15 - Lec 39 - Vibration of Rigid Bodies Part - 2
