A current of 200 A is passed through a stainless-steel wire [k = 19 W/m C] 3 mm in diameter. The resistivity of the steel may be taken as 70 u · cm, and the length of the wire is 1 m. The wire is submerged in a liquid at 110 °C and experiences a convection heat-transfer coefficient of 4kW/m •C. Calculate the center temperature %3D of the wire.
