File “Dockfig/Undockfig”:
File “BCH RiBM-based decoder”:
File “linearizor”:
File “Video: Cool Feature: VIP Demos”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=18206
File “PlotEpsTeX”:
File “linearizor”:
File “PlotEpsTeX”:
File “Load Open Document Spreadsheets”:
File “Closures in the MATLAB Language”:
File “Tektronix DPO4032 Oscilloscope”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=18225
File “Tektronix MSO4034 Oscilloscope”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=18226
File “anymate”:
File “Small Gui Example”:
File “Objective Image Fusion Performance Measure”:
File “sandpile”:
File “addcallback”:
File “Learning the Unscented Kalman Filter”:
File “Load Flow Gauss Siedel”:
File “TOGGLEFIG”:
File “NanoVis: molecular visualizator”:
File “erfi function”:
File “Column-weight three Girth-8 QCL-PDC Codes”:
File “demoXlsVbaMATLAB”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=18241
File “Adaptive Affinity Propagation clustering”:
File “Semi-supervised Affinity Propagation clustering”:
File “the fft file by myself”:
File “XML data import”:
File “1D Damped MUSIC (DMUSIC) Algorithm”:
File “Turbo Coding For Generic RSC Coders.”:
File “Minimal Bounding Box”:
File “Girth-twelve column-weight two QC-LDPC codes”:
File “Simualtion of Color Noise”:
الرجاء اخوتى الاعزاء افادتى
ابحث عن كود بالماتلاب يقوم بارسال الصوت مباشرة من المايكروفون الى السماعة
اى تتكلم من خلال المايك يطلع الصوت بالماعة فى نفس الوقت
بالتوفيق للجميع
File “Mouse scroll wheel naviagtion”:
File “myLabel 0.04”:
File “Advanced Data Visualization”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=18275
File “Unconstrained Optimization using the Extended Kalman Filter”:
File “Neural Network training using the Extended Kalman Filter”:
File “expandAxes”:
File “Simple waitbar”:
File “Fit continued fraction to data”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16666
File “Noise Suppressor Using Adaptive Filters”:
File “Simulate a Cox-Ingersoll-Ross process”:
File “ViewerTools”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16673
File “Memory File (mfile)”:
File “java_web_figures_demo”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16635
File “Film-like tone reproduction operator”:
File “Post Preprocessing Templates”:
File “OFDM with QPSK”:
File “OFDM with 16-QAM”:
File “OFDM with 64-QAM”:
File “Audio Noise Suppressor”:
File “Send Text Message to Cell Phone”:
File “setFigDockGroup”:
File “interleave”:
File “PolySpace Stats”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16928
File “region adjacency graph”:
File “Interface with measurement computing usb 3110 using dll”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16943
File “Retain the most recent or oldest figures”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16947
File “Pareto Member”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16951
File “epscombine”:
File “Convert fig files to images”:
File “Face Normalization”:
File “Dassl Mex file compilation to Matlab 5.3 and 6.5!”:
File “Visualize sparsity pattern”:
File “strrel”:
File “Image Rotation Correction”:
File “fastsearch”:
File “What?s New in Simulink? 7 for Model-Based Design webinar (October 4, 2007)”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16983
File “High Dimensional Discriminant Analysis”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16990
File “neighbor indexing”:
File “Toolbox for dynamical systems and time series analysis”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16994
File “Movingslope”:
File “BLOCKFUN applies function on sub blocks of an array”:
File “Dasslc Mex file compilation to Matlab 5.3 and 6.5!”:
File “What’s New for MATLAB in R2007b”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17002
File “CheckMate demos”:
File “Solution of 2nd order differential equation by rayleigh ritz method”:
File “LBM for poiseuille flow”:
File “PCA-based Face Recognition System”:
File “OFDM with QPSK for R14”:
File “OFDM with 16-QAM for R14”:
File “Modeling feedback loop using MATLAB and Simulink”:
File “Modeling feedback loop in MATLAB”:
File “Phonebook”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17048
File “filtfilthd”:
File “FLD-based Face Recognition System”:
File “Software Engineer”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17071
File “PolySpace In CodeWright”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17144
File “RSA6100A 3D Display”:
File “Set figures and scopes to be always on top”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17166
File “Power Cables Characteristics”:
File “HDF5TOOLS”:
File “Collecting data from RSA6100A”:
File “sendTxt.exe”:
File “Stability Test of AQM Network”:
File “ini2struct”:
File “changeSampleFreq”:
File “Using Statistics to Analyze Uncertainty in System Models”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17189
File “Treemap”:
File “findSteadyState”:
File “kernel density estimation”:
File “smartnormalized”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17215
File “pass_protect”:
File “image gallery”:
File “Construction of Regular Gallagher Parity Check”:
File “Circumcircle of a triangle”:
File “Circular Buffer”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17301
File “Constrained LLA to predict a chaotic time series”:
File “getversion: find MATLAB version number as a double”:
File “CirculaBuffer”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17286
File “Physical Modeling Workshop Exercises”:
File “DynamicPlot: An example of handle semantics with MATLAB classes”:
File “Open working directory (owd)”:
File “Developing custom modulation schemes”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17263
File “Visualize payoffs of an option strategy”:
File “Piecewise parabolic interpolation”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17412
File “Biparabolic interpolation”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17413
File “func_cart2pol”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17388
File “Function Approximation Using Neural Network Without using Toolbox”:
File “Set Covering Machine Toolbox”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17383
File “Fourier Series Tool”:
File “dijsktra”:
File “Cycloconverter”:
File “K-NN mex”:
File “Stateflow Design Patterns (Part III)”:
File “Reverberation Time Calculator”:
File “Autonomous Navigation”:
File “Hydromechanical Systems in Simulink Part 2”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17435
File “Fast Gaussian Transform mex implementation”:
File “Generation of Gold Codes”:
File “checkfield”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17441
File “getimagenames”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=17443
