يعنى يحصل على الدائره short circuit
short circuit
وى شكرا
A short circuit (sometimes known as simply a short) is a fault whereby electricity moves through a circuit in an unintended path, usually due to a connection forming where none was expected. This unintended path often has a very low resistance which means that a much larger current than normal flows, potentially causing overheating, fire or explosion.
The electrical opposite of a short circuit (zero resistance between input voltage and ground) is an open circuit (infinite resistance between input voltage and ground).
جزاكم الله خيرا للتوضيح
وفيتم و كفيتم
انا عاوز اعرف الشورت سيركت
