برامج ماتلاب 42 : 50
#1
File “Cardiac-Simulink with Model Pacemaker VI1 Of Cardiac Cells”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15811
File “Pause finder”:
File “xDSL_Bitloading”:
File “isalmost”:
File “Upslope area functions”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15818
#2
File “Soft Handover Probability as a funiction of the Soft Handover Threshold”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15824
File “isedm”:
File “GetJFrame - Retrieves a figure’s underlying Java frame”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15830
File “Space Arc System Analysis with Flexibility Stiffness and Linear Static Method (update:05-08-07)”:
File “OFDMA Signal mapping process”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15833
File “Export data to SAS”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15834
File “Import data from SAS”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15835
File “Retrieve online content with Matlab”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15836
File “A 32 point FFT in embedded MATLAB using fixed point arithmetic”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15837
File “Animated Peaks and Spheres”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15838
File “Designing Algorith and Programation Of Cardiac Software Guide with Mat Lab”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15840
File “Parabola detection using Hough Transform”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15841
File “finding the irreducible representations linearly”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15842
File “Control Algorithm Modeling Guidelines Using MATLAB®, Simulink®, and Stateflow® - Version 2.0”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15844
File “DSPLOT - downsampled plot”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15850
#3
File “Piecewise defined function builder”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15851
File “Example: Creating TimeSeries and TsArray Inputs for Simulink Bus Signal Input Data”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15852
File “Measuring Mass Moment of Inertia with a Bifilar Pendulum”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15854
File “retain”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15855
File “polycenter”:
http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15856
#4
File “Space Elastic Frame Analysis with Linear Static Applications (update:08-09-07)”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15878
File “Get user home directory”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15885
File “Get application data directory”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15886
File “Make MATLAB Talk”:
File “enable/disable figure”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15895
File “waitbar for a mexFunction, example”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15898
File “Analytical intersection area between two circles”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15899
File “subdir: a recursive file search”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15859
File “Count the number of the girth 4 of LDPC codes”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15860
File “Hurwitz-Schur Stability Test of 2-D Polynomials”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15862
File “DirectShow (DirectX) based Video file reader”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15864
File “Volume Visualization Example”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15867
File “Flow Graph Analysis Tool Gui”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15868
File “Video tutorial: reading Excel data into MATLAB”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15869
File “Video tutorial: Refactoring a script into a function”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15870
File “Video tutorial:Building a GUI for reading Excel data into MATLAB”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15871
File “Demo Files for “Data Analysis with Statistics and Curve Fitting Toolboxes” 2007 Webinar”:
#5
File “Yet Another Calendar”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15913
File “Resize dataset”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15914
File “Hamiltonian operation on Lattice”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15915
File “Generalized Laguerre polynomial”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15916
File “2D matrix smoothing”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15917
File “Hausdorff Dimension by the box counting method”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15918
File “EyeMap”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15900
File “OLS”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15902
File “curvcoord”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15903
File “Path Loss”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15907
File “Y Bus Formation”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15908
File “EMBLRead”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15909
File “Convert File Format”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=15910
#6
File “M-File Comput N°1 Of Model Pacemaker VI1 Of All The Cardiac Cells With R2007a”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16039
File “EVM Computation in Simulink”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16043
File “Weighted Geometric Mean”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16045
File “Stack all figures”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16046
File “Store Excel named range in MATLAB”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16047
File “Plot a multimodal distribution in 3D”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16053
#7
File “Cascade”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16002
File “tick2text: create easy-to-customize tick labels”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16003
File “Gray coded matrix”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16019
File “ACQREAD”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16023
File “Calling functions from a user defined shared library”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16026
File “corrcoef_directional.m”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16028
File “MATLAB oscilloscope application - simplified example”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16029
File “Sliding Spectrometer”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16032
File “Cleve?s Corner: Parallel MATLAB - Multiple Processors and Multiple Cores”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16033
File “Programming Patterns: Maximizing Code Performance by Optimizing Memory Access”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16034
File “Research Focus: Using Laboratory Models to Understand Avalanche Dynamics”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16036
File “ANIMATOR - animate data”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16037
File “MATLAB and Simulink in the World: Earth, Ocean, and Planetary Sciences”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16038
#8
File “Axis_Prunelabels – clean up redundant axis labels”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16115
File “Pitzer Inertias”:
File “High Dimensional Data Clustering (HDDC)”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16122
File “Seam Carving for content aware resizing”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16123
File “findFWHM”:
File “Plot a Directed Graph”:
File “Video: MATLAB Basics: Subsets of a matrix, row and column indexing”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16132
File “Video: MATLAB Basics: Subsets of a matrix, absolute and logical indexing”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16133
File “Evolution”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16136
File “Calculate Rationalized arcsine transform”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16139
File “Angular Mathieu Functions”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16128
File “Simulink I/O Align Tool”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16129
#9
File “Schur Stability Test of 2-D Polynomials”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16092
File “Polar Coordinates Transform”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16094
File “uniquify”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16098
File “Write Epson ESC/P2 file”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16099
File “Modelling registers in Embedded MATLAB”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16100
File “Frequency Response of the Ear , Hearing Test”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16101
File “Finite Differences Beam Propagation Method in 3-D”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16102
File “Clebisch Gordon Coefficient Solver GUI”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16107
#10
File “BEM Code for 2D Pulsating Cylinder”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16074
File “Textscantool”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16075
File “waitmex: using a waitbar inside a C mexFunction”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16076
File “Patch Antenna Design Using Sonnet v3.0”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16077
File “Application Deployment with MATLAB (July 2007)”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16078
File “Project-specific preferences, settings, and history”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16088
File “Video: MATLAB Basics: Sorting a matrix by rows”: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=16234
