RAYA Telecom – has a vacancy for a junior position in IT Department.
Required job Title: Application Developer.
Qualifications:
[ol]
[li]
Computer engineering/science is preferred but not required. [/li]A graduate from minimum of four years college/faculty with a minimum grade of good is a MUST, if not your application will be ignored.
At least one year solid programming knowledge in OOP, C#, .Net (ASP.Net 1.0, 2.0) is a MUST, also fresh graduate with solid knowledge are welcome.
Good Knowledge about Database Concepts and Design is a MUST.
Can handle gathering requirements/design/implementation/testing & documentation of desktop/web applications alone with minimum supervision is a great plus.
Knowledge in Design/Development/Administration of MS SQL (2000/2005) is a plus.
Knowledge in Design/Development/Administration of Oracle (9i/10g) is a plus.
Knowledge in MS SPS 2003 is a plus.
[li]
Extra knowledge about Database warehousing is a great plus.
[/li][/ol]General qualification:
[FONT=Arial]
[/font][LEFT]Good programming/documentation skills are required.
2. Analytical thinking and very organized thoughts of problem solving.
3. Self motivated and self learner.
4. Capability to work in a very dynamic environment.
5. Quality and creativity of work is a major factor, not just a programmer
Benefits you get from working with us:
1. Great added value for your career to work in multinational environment.
2. Solid motivated/learning environment.
3. You will experience the team work spirit and find people that will educate you.
How to apply:
Send a CV with a covering letter including a small paragraph about your self, and a sample of your work including your own coding (Sample code will be reviewed and tested).
[FONT=Arial]
it.2007.rt @ gmail.com
[/left]
[/font]
[LEFT]With subject Application developer.
[/left]
