طلب حل مساله في التكييف
(system) #1
السلام عليكم ورحمة الله
ممكن حل مسأله بسيطه في التكييف
المسأله هي
[FONT=TimesNewRoman]
The following design specifications are provided for the air conditioning of a high humidity
chamber.
Outside design conditions: 35ºC DB, 25 ºC WB
Inside design conditions: 21ºC DB, 70% RH
Room sensible heat: 80 kW
Room latent heat: 5 kW
Coil by-pass factor: 0.1
Outside air ventilation: 1950 l/s
Calculate:
a. Outdoor air load (OATH)
b. Grand total heat (GTH)
c. Effective sensible heat factor (ESHF)
d. Apparatus dew point (ADP)
e. Dehumidified air quantity (l/s)
f. Entering and leaving conditions at apparatus
g. Condensate flow rate
وجزاكم الله خيرا
[/font]
(doren) #2
الموضع غير واضح
