ممكن مساعدة في حل السؤال
(مهندسة2009) #1
السؤال هو التالي:
[LEFT]Fresh organic juice contains 12% by mass of solids, besides the balance water, and concentrated organic juice contains 42% by mass solids. Initially a single evaporation process was used for the concentration, but volatile constituents of the juice escaped with the water, leaving the concentrate with flat taste. The current process overcomes this problem by bypassing the evaporator with a fraction of the fresh juice. The juice that enters the evapotator is concentrated to 58%
(by mass). And the evaporator product stream is mixed with the bypassed fresh juice to achieve the desired final concentration.
a) Draw and label a flowchart of this process, neglecting the vaporization of everything in the juice but water. First prove that the subsystem containing the point where the bypass stream splits off from the evaporator feed has one degree of freedom. Then perform the degree-of-freedom analysis for all subsystems. And then write (in order) the equations you would solve to determine all unknown stream variables.
b) Calculate the amount of product (42% by mass concentrate) produced per 100 kg fresh juice fed to the process and the
fraction of the feed that bypass the evaporator.
[/left]
جزاكم الله كل خير
مهندسة2009
(المهندسة قطوة؟!!!) #2
في البداية يقول انه عندج عصير برتقال يحتوي على 12% من عصير و الباقي ماء
اي (100-12)%
وعندج ايضا عصير مركز يحتوي على 42% برتقال والباقي ماء… (ناتج نهائي)
العملية
تمرير عصير البرتقال في المبخر حيث تركيز العصير 58% والباقي ماء
عندما تم ادخال العصير في المبخر تطاير جزء من العصير مع الماء، وبقى عصير المركز
هذا العصير المركز خرج من المبخر وتم خلطه مع عصير فرش (اعتقدFresh organic juice contains 12%) للحصول على (concentrated organic juice contains 42%)
وهكذا ترسمي الشارت…
ان شاء الباقي بحاول افكر فيه بعدين…
وان شاء الله اكون قدرت اساعدج
وهذا والله اعلم
:slight_smile:
