ارجو المساعده
[SIZE=4][CENTER]
ساعدوني في حل هذه الاسئله ببرنامج المات لاب
ارجوووو المساعده بلييييييز
هذا اسايمنت و تسليمه قريب ماشي وقت ساعدوني الله يخليكم
Write a script that will continue prompting the user for positive numbers, and
storing them in a vector variable, until the user types a negative number
Write a script that will use the menu function to present the user with choices
for functions fix, floor, and ceil. Error-check by looping to display the menu
until the user pushes one of the buttons (an error could occur if the user clicks
the X on the menu box rather than pushing one of the buttons). Then, generate a
random number and print the result of the user’s function choice of that number
.(e.g., fix(5))[/size]
[LEFT][COLOR=#000000]
[/color][/left]
