أنا جديد في برنامج الماتلاب
فياريت أجد أحد يساعدني في كتابة هذا الكود مشكورين مقدماُ
- Write code to do the following:
a. Generate a random sized array of random numbers using: x = 10rand(ceil(10rand)+2,1)
b. Use “for” loop to add up all the values in the array and assign the result to the variable sumx.
i. For example, if the array is x = [1 1 1 1 1 1 1 1 1 2], then the sum of all the elements would be sumx = 11.
c. Check your answer using the built-in MATLAB sum( ) function by adding the following code snippet to the end of your script. if sumx == sum(x) disp(‘Congratulations!!, you did it right’) load handel;sound(y,Fs) else fprintf(‘Sorry, %.2f ~= %.2f. Please try again.
’,sumx,sum(x)) end
d. Repeat but use a “while” loop this time. - Use the MATLAB publish feature to publish your script to a Word file. No title page is required for this exercise.
