اخواني بغيت تصميم لحساس كهربائي يقيس المسافة … هذا السؤال عليه 20 درجة … أتمنى منكم مساعدتي لو بملاحظات بسيطة ممكن تفيدني
“هنا السؤال كامل”
Using the appropriate sensors and circuits, Design a complete circuit to perform the following task:
It is required to design a system that can detect any moving object at a distance between 1-1.5m from the system. Also, the detection is only for the case when the object is moving towards the system not in any other direction. Design the system using only analogue circuits, other designs options such as using microprocessor or microcontrollers are not acceptable
وشكراً
