تعاريف مهمه لمهندس الافيونكس
Negative electrode:
The electrode from which electrons flow when the battery is discharging into an
external circuit. Reactants are electrochemically oxidized at the negative electrode. In the lead-acid
cell, the negative electrode contains spongy lead and lead sulfate (PbSO4) as the active materials.
In the nickel-cadmium cell, the negative electrode contains cadmium and cadmium hydroxide
(Cd(OH)2) as the active materials.
Nominal voltage:
The characteristic operating voltage of a cell or battery. The nominal voltage is 2.0 V
for lead-acid cells and 1.2 V for nickel-cadmium cells. These voltage levels represent the approxi-
mate cell voltage during discharge at the C-rate under room-temperature conditions. The actual
discharge voltage depends on the state-of-charge, state-of-health, discharge time, rate, and tem-
perature.
Positive electrode:
The electrode to which electrons flow when the battery is discharging into an external
circuit. Reactants are electrochemically reduced at the positive electrode. In the lead-acid cell, the
positive electrode contains lead dioxide (PbO2) and lead sulfate (PbSO4) as the active materials.
In the nickel-cadmium cell, the positive electrode contains nickel oxyhydroxide (NiOOH) and
nickel hydroxide (Ni(OH)2) as the active materials.
Separator:
An electrically insulating material that is used to prevent metallic contact between the positive
and negative plates in a cell, but permits the flow of ions between the plates. In flooded cells, the
separator includes a gas barrier to prevent gas diffusion and recombination of oxygen. In sealed
cells, the separator is intended to allow gas diffusion to promote high recombination efficiency.
State-of-charge:
The available capacity of a battery divided by the capacity available when fully charged,
normally expressed on a percentage basis. Sometimes referred to as “true state-of-charge.’’
State-of-health:
The available capacity of a fully charged battery divided by the rated capacity of the
battery, normally expressed on a percentage basis. Sometimes referred to as “apparent state-of-
charge.” Can also be used in a more qualitative sense to indicate the general condition of the battery.
Ampere-hour capacity:
The quantity of stored electrical energy, measured in ampere-hours, that the
battery can deliver from its completely charged state to its discharged state. The dischargeable capacity
depends on the rate at which the battery is discharged; at higher discharge rates the available
capacity is reduced.
C-rate:
The discharge rate, in amperes, at which a battery can deliver 1 h of capacity to a fixed voltage
endpoint (typically 18 or 20 V for a 24-V battery). Fractions or multiples of the C-rate also are
used. C/2 refers to the rate at which a battery will discharge its capacity in 2 h; 2C is twice the C-
rate or that rate at which the battery will discharge its capacity in 0.5 h. This rating system helps
to compare the performance of different sizes of cells.
CCA:
The numerical value of the current, in amperes, that a fully charged lead-acid battery can deliver
at 18°C (0°F) for 30 s to a voltage of 1.2 V per cell (i.e., 14.4 V for a 24-V battery). In some cases,
60 s is used instead of 30 s. CCA stands for cold cranking amperes.
Electrolyte:
An ionically conductive, liquid medium that allows ions to flow between the positive and
negative plates of a cell. In lead-acid cells, the electrolyte is a mixture of sulfuric acid (H2SO4) and
deionized water. In nickel-cadmium cells, the electrolyte is a mixture of potassium hydroxide
(KOH) dissolved in deionized water.
Imp:
The numerical value of the current, in amperes, delivered after 15 s during a constant voltage
discharge of 0.6 V per cell (i.e., at 12 V for a 24-V battery). The Imp rating normally is based on
a battery temperature of 23°C (75°F), but manufacturers generally can supply Imp data at lower
temperatures as well.
Monobloc:
A group of two or more cells connected in series and housed in a one-piece enclosure with
suitable dividing walls between cell compartments. Typical monoblocs come in 6-V, 12-V, or 24-v
configurations. Monoblocs are commonly used in lead-acid batteries, but rarely used in nickel-
cadmium aircraft batteries.
منقوله من كتاب
مذكرات في الافيونكس
وهذه مصطلحات لمهندس الافيونكس
ACE: Actuator Control Electronics
ADIRU: Air Data Inertial Reference Unit
ADM: Air Data Module (Static and Total Pressure)
AFDC: Autopilot Flight Director Computer
AIMS: Airplane Information Management System
ARINC: Aeronautical Radio Inc. (Industry Standard)
C: Center
C*U: Pitch Control Law utilized in the Primary Flight Computer
CMC: Central Maintenance Computer Function in AIMS
DCGF: Data Conversion Gateway Function of AIMS
EDIU: Engine Data Interface Unit
EICAS: Engine Indication and Crew Alerting System
ELMS: Electrical Load Management System
FBW: Fly-By-Wire
FCDC: Flight Controls Direct Current (power system)
FSEU: Flap Slat Electronic Unit
L: Left
L1: Left 1
L2: Left 2
LRRA: Low Range Radio Altimeter
LRU: Line Replaceable Unit
MAT: Maintenance Access Terminal
MEL: Minimum Equipment List
MFD: Multi-Function Display
MOV: Motor-Operated Valve
PCU: Power Control Unit (hydraulic actuator)
PFC: Primary Flight Computer
PMG: Permanent Magnet Generator
PSA: Power Supply Assembly
R: Right
RAT: Ram Air Turbine
SAARU: Standby Attitude and Air Data Unit
TAC: Thrust Asymmetry Compensation
WEU: Warning Electronics Unit
ADS-B Automated Dependent Surveillance-Broadcast
AMASS Airport Movement Area Safety System
ASDE Airport Surface Detection Equipment
ATC Air Traffic Control
CDTI Cockpit Display of Traffic Information
CFIT Controlled Flight into Terrain
CPDLC Controller Pilot Datalink Communications
DGPS Differential Global Positioning System
EuroCAE European Organisation for Civil Aviation Equipment
FAA Federal Aviation Administration
GA General Aviation
GHz Gigahertz
GPS Global Positioning System
HUD Head-Up Display
IFR Instrument Flight Rules
IMC Instrument Meteorological Conditions
LAAS Local Area Augmentation System
NASA National Aeronautics and Space Administration
Nav Navigation
NIMA National Imagery and Mapping Agency
NOAA National Oceanic and Atmospheric Administration
NPRM Notice of Proposed Rulemaking
PFD Primary Flight Display
RI Runway Incursion
RIRP Runway Incursion Reduction Program
RTCA Requirements and Technical Concepts for Aviation
SC Special Committee
SRTM Space Shuttle Radar Topography Mission
TAWS Terrain Awareness Warning Systems
TCAS Traffic Alert and Collision Avoidance System
TIS-B Traffic Information Services — Broadcast
VMC Visual Meteorological Conditions
WAAS Wide Area Augmentation System
WG Working Group
منقوله من كتاب
مذكرات في الافيونكس
هل هذا قاموس
لا يا اخي msi ده مش قاموس ده كتاب موجود في المنتدى بتاعنا اسمهhandbook of avionecs يعني مذكرات في الافيونكس وده مصطلحات فادتني شويه فيه فقررت اني ارفعها في المنتده يمكن تفيدكوا انتوا كمان
وبارك الله فيك
http://www.almohandes.org/vb/showthread.php?p=84621#post84621
الكتاب في المنتدى
