copy the links below in flashget and download them to your computer
there are 26 flash tutorials
links
http://www.ansys.com/techmedia/1-create_rectangle.swf
http://www.ansys.com/techmedia/1-define_rectangles.swf
http://www.ansys.com/techmedia/2-add_hole_circles.swf
http://www.ansys.com/techmedia/2-change_plot_controls_and_replot.swf
http://www.ansys.com/techmedia/3-change_wp_to_polar_create_first_circle.swf
http://www.ansys.com/techmedia/3-dimension_hole_circles.swf
http://www.ansys.com/techmedia/4-display_name.swf
http://www.ansys.com/techmedia/4-move_wp_create_second_circle.swf
http://www.ansys.com/techmedia/5-add_areas.swf
http://www.ansys.com/techmedia/5-generate_3_d.swf
http://www.ansys.com/techmedia/6-change_dimension.swf
http://www.ansys.com/techmedia/6-create_line_fillet.swf
http://www.ansys.com/techmedia/7-add_3d_blend.swf
http://www.ansys.com/techmedia/7-create_fillet_area.swf
http://www.ansys.com/techmedia/8-add_areas_together.swf
http://www.ansys.com/techmedia/8-generate_parameters.swf
http://www.ansys.com/techmedia/9-create_first_pin_hole.swf
http://www.ansys.com/techmedia/9-run_in_ds.swf
http://www.ansys.com/techmedia/10-move_wp_create_second_pin_hole.swf
http://www.ansys.com/techmedia/11-subtract_pin_holes_from_bracket.swf
http://www.ansys.com/techmedia/12-save_as_model_db.swf
http://www.ansys.com/techmedia/13-set_preferences.swf
http://www.ansys.com/techmedia/14-define_material_properties.swf
http://www.ansys.com/techmedia/15-define_element_type_and_options.swf
http://www.ansys.com/techmedia/16-define_real_constants.swf
http://www.ansys.com/techmedia/17-mesh_the_area.swf
http://www.ansys.com/techmedia/18-save_as_mesh_db.swf
http://www.ansys.com/techmedia/19-apply_displacement_constraints.swf
http://www.ansys.com/techmedia/20-apply_pressure_load.swf
http://www.ansys.com/techmedia/21-solve.swf
http://www.ansys.com/techmedia/22-enter_g_p_and_read_results.swf
http://www.ansys.com/techmedia/23-plot_the_deformed_shape.swf
http://www.ansys.com/techmedia/24-plot_von_mises_eqv_stress.swf
http://www.ansys.com/techmedia/25-list_reaction_solution.swf
http://www.ansys.com/techmedia/26-exit_ansys_pgm.swf
Please note this post from brother New Tiger Damasgate.
