هذا اختبار بسيط لكل المهندسين المبتدئين سواء خريجين او طلبه فى قسم القوى والالات الكهربية وارجو من الجميع عدم الاستهتار والتهاون وحاول تختبر نفسك وشوف مستواك فى اساسيات الكهرباء
In a synchronous motor the field revolves:
i) Exactly in step with the rotor.
ii) In front of the rotor.
iii) Behind the rotor. -
If an actuator brake coil is open-circuited the actuator will:
i) Run at reduced speed.
ii) Overrun.
iii) Stop. -
The correct electrolyte for a lead acid battery is:
i) Potassium hydroxide.
ii) Lead peroxide.
iii) Sulphuric acid. -
A Ni-Cad battery consists of 19, 1.2 volt cells. What will the nominal battery output be?
i) 20 V
ii) 22 V
iii) 24 V -
The correct neutralizing agent used in a lead acid battery is :
i) Bicarbonate of soda.
ii) Potassium hydroxide.
iii) Water. -
The preferred method of battery charging a Ni-Cad battery is:
i) Const. voltage.
ii) Const. current.
iii) Const. speed. -
The output of a DC. generator is controlled by varying the:
i) Engine speed.
ii) Armature current.
iii) Field current. -
The output of a light A/C’s alternator is:
i) A DC. Voltage.
ii) Single phase AC.
iii) 3 phase AC. -
The 3 phase voltage generated within an alternator is converted to DC. by:
i) The voltage regulator.
ii) The rotating diodes.
iii) The armature. -
The generator output can be measured by using:
i) A voltmeter.
ii) An ammeter.
iii) A tachometer. -
The CSD ensures that:
i) The engine speed remains const..
ii) The generator is adequately cooled.
iii) The generator speed remains const. -
Which of these factors affecting the output voltage of a DC. generator is normally controlled?
i) Field current.
ii) The number of conductors in the armature.
iii) Generator speed. -
In a carbon pile regulator the core resistance is varied by:
i) A spring.
ii) Generator load current.
iii) Electro-magnetic force. -
Generator load sharing is applicable to:
i) AC. and DC. Generators.
ii) AC. generators only.
iii) DC. Generators only. -
In an AC. generator SYS, reactive load sharing is achieved by controlling:
i) Generator speed.
ii) Generator field current.
iii) Generator current. -
Real load is measured in:
i) Watts.
ii) Volt amps.
iii) Joules. -
Output voltage levels from a rotary inverter are controlled by:
i) Varying the speed of the DC. Motor.
ii) Adjustment of the output voltage of each phase.
iii) Varying the generator field excitation current. -
The output frequency of an inverter is controlled by:
ii) Varying the generator field current.
iii) Switching the DC. Supply. -
The output voltage is measured by:
i) An ammeter.
ii) A voltmeter.
iii) An annunciator. -
Static inverters are usually employed to provide :
i) Emergency power to essential loads.
ii) Continuous power to flight instruments.
iii) Emergency power to instruments in the event of inverter failure. -
The output frequency of a static inverter is:
i) 50 Hz.
ii) 400 Hz.
iii) 1500 Hz. -
The number of circuits which can be completed through the poles of a switch is identified by the term:
i) Toggle.
ii) Throw.
iii) Position. -
A relay with a moving core is usually known as a:
i) Solenoid.
ii) Polarised relay.
iii) Proximity switch. -
In a moving coil meter, the coil is wound on to:
i) A permanent magnet.
ii) Part of the control springs.
iii) An iron core, which is pivoted. -
What is the colour of a warning light?
i) Red.
ii) Amber.
iii) Blue. -
How is an ammeter connected to measure generator load?
i) In parallel with the load.
ii) In an open circuit with the load.
iii) In series with the load. -
Larger sizes of aluminium cables when installed:
i) Save weight.
ii) Are more reliable.
iii) Use less space. -
Which is the largest wire size for A/C use?
i) 40 AWG.
ii) 1 AWG.
iii) 00 AWG. -
Crimped terminals are more satisfactory because:
i) Special tools are not required.
ii) Conductor flexibility is retained.
iii) A skilled engineer must carry out the crimp. -
Attachment of conductors to pin and socket contacts is mainly done by:
i) Crimping.
ii) Soldering.
iii) Adhesive.
32) Aluminium conductors are terminated with lugs made from:
i) Copper.
ii) stainless steel
iii) Aluminium copper alloy.
منتدى المهندسين
مهندس وائل خطاب
