Abstract: Behind every hydraulic system there exists
critical components that influence power transmission. To
improve talent you should recognize how these
components operate and affect the system i.e. learn the
kinds of filter and piping used in hydraulic systems,
describe the types and functions of hydraulic seals, and
explain the operating principles of different types of
pumps, and further learning the types and uses of
accumulators, control valves, relief valves, cylinders, and
even actuators.
In this research study appropriate problem-solving
processes are applied, and this helps to comprehend the
hydraulic concepts and hydraulic schematic
representations. Therefore, it will enhance the knowledge
and the capacity of troubleshooting the different
hydraulics systems in the cement industry. This will enable
the person to stay on top of the industry practices in
hydraulics, explore the basics of a hydraulic system by
reviewing the types and properties of hydraulic fluids,
identifying the symbols used on hydraulic schematic
representations, and explaining hydraulic circuit
operations based on a schematic design.
62-82, Tesma0708,IJEAST.pdf (653.6% u)
