The cement material is considered to be of great importance in different aspects of building development projects and as a commodity for export and investment. Accordingly, the product should be compatible with the standard specifications within manufacturing stages to ensure acceptable quality. This research paper focuses on creating a system that monitors and records daily readings of cement physical tests at quality laboratories of cement factory and accordingly the control charts for each test were established. The importance of control charts for the variables lies in the expression of the system status (inside or outside the control limits); normally the points which are located outside the borders indicate that the system is out of control. But in some cases, the points are within the control limits but took an abnormal distribution. First, the system determines the style of pattern type, analyzes and then finds out the expected causes and suggests the solutions. The system was tested by inserting different records in different intervals of time; the results obtained were reasonable and had explained the effectiveness of the system.IJOAEM Vol 3 Mo 4 Paper 5.pdf (376.4% u)
