[LEFT]The pump is a mechanical device which converts the mechanical energy of its driving unit (electric motor, gas turbine, wind turbine, steam turbine, diesel engine,…etc) into hydraulic energy. This hydraulic energy increases the energy of the pumped liquid and enabled it overcome the static head and the hydraulic losses of the piping system in which the pump is interposed.
The method that is used to supply the energy to the pumped liquid determines the category into which the pump is placed, so there are two types of categories where the pump can be classified: Roto-dynamic pumps and positive displacement pumps.
We will discuss these types in details in the following article.
Pump is an important device which we can’t neglect it in our world because…
to continue this article, you should go to my site now
http://www.pumpseng.blogspot.com [/left]
