In this research paper, a Bajaj rickshaw vehicle was
tested under variable loads and five different oil - fuel mixture
ratios ranging between 2% and 12.5%. Three readings of each
experiment were taken and average values were extracted.
It was found that oil - fuel mixture ratios which lie
between 2% and 5% are the most suitable ratios that could be
used by rickshaw drivers and technician mechanics. These
ratios are recommended to be used because they give the
vehicle’s engine higher acceleration, longer operation period
life, diverge the overhaul maintenance period intervals, and
that they cause less impact to the surrounding environment.document.pdf (681.8% u)
